Thread Number: 5451
Bissell ProHeat Questions |
Post# 60582 , Reply# 5   2/16/2009 at 08:08 (5,546 days old) by vacfanatic (Omaha, NE)   |   | |
After I use my ProHeat 2x, I flush it out with clean water, both the solution tank, and again through the clean water tank. To make sure it's totally cleaned out, I spray both from the carpet cleaning mode as well as the upholstry tool. I also make sure to rotate the mix knob back and forth through all of the settings, to make sure that all solution is flushed out. Hopefully this will keep the pump and heater from clogging as I have read others have experienced on other websites before.
