Thread Number: 3843
I'm back with an Electrolux find today |
Post# 43715   6/13/2008 at 19:02 (5,767 days old) by petek (Ontario)   |   | |
Just got back from Toronto yesterday and hit the local Goodwill here today and found this Electrolux AP100 with attachments. Oddly it was packed under a table in a Panasonic canister box. |
Post# 43720 , Reply# 1   6/13/2008 at 19:33 (5,767 days old) by arh1953 ( River Park, in Port St. Lucie, Florida)   |   | |
Post# 43728 , Reply# 2   6/13/2008 at 21:20 (5,767 days old) by camelotshadow (Valley Village)   |   | |
Even your doggy is admiring it. I know we can't leave these things behind vanquished to become disregarded in the hands of those who could care less as its JUST a vacuum |
Post# 43735 , Reply# 3   6/13/2008 at 22:07 (5,767 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
That crevice tool looks kinda banged up...is that duct tape holding the tip together? I have a spare matching crevice tool for ya, Pete and yer gonna need a carpet nozzle to fill out the CarryAll Caddy. Nice find - these are the first Canadian models 1973-76 after the 80 series. Mostly metal under all that durable fleshtone plastic. The AP that preceed it is all one colour, the AP100 has the white top and the next AP200 has a jaundice yellow body. |
Post# 43739 , Reply# 4   6/13/2008 at 22:21 (5,767 days old) by luxg ()   |   | |
Pete, another great find!! Just wonder if that attachment caddy came with that machine?? I have seen one like that for the uprights but never the canister. |
Post# 43743 , Reply# 5   6/13/2008 at 23:46 (5,767 days old) by mihi ()   |   | |
Man, how do you find all the good stuff. I've been wanting an Electrolux real bad. We had one when I was growing up. Maybe some day. Very nice find there! |
Post# 43744 , Reply# 6   6/14/2008 at 00:21 (5,767 days old) by camelotshadow (Valley Village)   |   | |
Can't go wrong with Electrolux |
Post# 43881 , Reply# 8   6/16/2008 at 07:47 (5,764 days old) by chestermikeuk (Rainhill (Birthplace of the Railway),England, UK.)   |   | |
Post# 43883 , Reply# 9   6/16/2008 at 08:13 (5,764 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
That's a good sign, Pete. means the problem is in the accessable contacts. Handgrip swivels around the hose, right? There are two slip rings and matching contacts under that long piece that used to be used for the microswitch. There's a tiny -1/16" pin that holds the base in place along with the screw at the plug end. Ease the pin out with a 1/16" pin driver, allan key or a trim nail in vicegrips. The contacts are probably just greasy dirty or a contact spring needs bending. Clean up those rings with lighter fluid on a cloth while spinning. Perhaps some emory paper but don't use steel wool as particles will migrate inside causing a short eventually. Well, you know all that. If the slipring has grooves in it move the contacts a bit off to the side. |
Post# 43884 , Reply# 10   6/16/2008 at 08:27 (5,764 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 43885 , Reply# 11   6/16/2008 at 08:33 (5,764 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 43886 , Reply# 12   6/16/2008 at 08:37 (5,764 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 44712 , Reply# 14   6/23/2008 at 12:13 (5,757 days old) by collector2 (Moose Jaw, Sk)   |   | |
Hey Pete: It appears that its an AP200 (yellow) Pn you have with it in the pic. Put a PN100 cover on the list of things for me to send you (send the list with Dave if he gets down this way this year) LOL. The accessory kits were made to be either carried around or wall mounted. The small slot above the handle matches up with a hook on the bottom of the kit so you could mount one on the closet wall (via the screw slots) to hold bags etc then hook a second one for the parts on below it. In that way you could take the parts with you. You'll notice it also has low sides and a higher front. That was so that the hose could be hung over it. I've also seen them screwed together back to back, in the fashion of the older cardboard kits to make a larger kit to handle all the cleaning supplies. Doug |
