Thread Number: 36829
Restoring Yellowed Hoover Convertible Cleaner Head - Leave It In The Sun! |
Post# 393991   6/28/2018 at 11:47 (2,128 days old) by AlexHoovers94 (Manchester UK)   |   | |
Hello all, I figured, since summer was here, I would restore some of the plastics on my vacuums that had turned yellow due to aging. The process may be familiar to some of you, known as “retro brighting”.
All you really need for this is the hot direct UV raise of the sun, which for best results, you need to do this on a hot summers day, that is not overcast. You need 12% 40 volume cream peroxide, (used for hair colouring) a brush for pasting the peroxide onto the items you would like to work on and a clear plastic box: The box is to cover the peroxide pasted items to prevent the solution from drying out. Before you start, you need to make sure the plastic you want to restore is clean and dry, then you paste the peroxide on with the brush so that all the yellowed plastic is EVENLY covered, the layer of peroxide pasted onto the plastic needs to be of Goldilox consistency, not too much, not too little. Set your parts in the hot sun and put the clear box over them and leave alone for the chemical reaction to take place! Be sure to check the parts every 30 minuets and move them around, so they get even coverage of the UV raise. Once you see the yellowing has gone, wash off the peroxide and bobs your uncle! Check the plastic to see if you have an even finish, if there are areas that are still a bit yellow, repeat the process. Remember, this is a skill, so practice on something that is not of value to you, before attempting to restore something that is! Hope you enjoyed this post, thanks for reading, Alex. |
Post# 393992 , Reply# 1   6/28/2018 at 11:59 (2,128 days old) by cuffs054 (monticello, ga)   |   | |
That's impressive! |
Post# 393996 , Reply# 2   6/28/2018 at 12:52 (2,128 days old) by TheSpiritOf76 ()   |   | |
There are no other words for it! I have a few things that I need to do that too...Its really nice sunny and hot here in Kansas right now. You now have me about inspired. |
Post# 393998 , Reply# 3   6/28/2018 at 13:29 (2,128 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Yep, I knew about this for about 10 years from my videogame hobby, people do this to the NES and SNES. I never did it though because mine are not that bad and it doesn't bother me. It works great when you get the paste right, but this process is only temporary though, it will have to be redone every few years until the plastic wears out from all the chemical treatment. It's just the nature of ABS plastic. They wanted to make a cheap, affordable plastic composite but didn't bother to faff about with making sure it was U/V safe long-term, so sunlight and general light exposure can really eat away at it.
Post# 394006 , Reply# 4   6/28/2018 at 14:20 (2,128 days old) by kenkart ()   |   | |
I have a model 70 Convertible that the blue hood has turned GREEN ...I wonder if this treatment would help it or turn it white??? |
Post# 394009 , Reply# 5   6/28/2018 at 14:41 (2,128 days old) by AlexHoovers94 (Manchester UK)   |   | |
Cuffs054/TheSpiritOf76
Thanks a lot, really impressed with the results! 😃😍 Huskyvacs I have read that it goes back to the way it was before over time, but what about if you kepts it stored in a cool dark place? I don’t understand how it can do that just on its own, as the brown tinge comes off into the peroxide...We’ll see, in the fullness of time! kenkart Yes, this process will work on coloured plastics but you must take extra care as it will show easily if you don’t spread the peroxide evenly, it can go patchy and don’t leave it out more than an hour as it will begin to fade the colour. So extra care must be taken if you want to use this process on coloured plastic but it will definitely work, as I said, it is a skill, so practice first! 🙂 Alex. |
Post# 394010 , Reply# 6   6/28/2018 at 15:08 (2,128 days old) by Ultralux88 (Denver, Colorado)   |   | |
Post# 394012 , Reply# 7   6/28/2018 at 16:59 (2,128 days old) by TheSpiritOf76 ()   |   | |
I have a Hoover Portable in Marine Blue, same color as the 1070. That is one I plan on using this process with. |
Post# 394018 , Reply# 9   6/28/2018 at 18:28 (2,127 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 394031 , Reply# 10   6/29/2018 at 01:33 (2,127 days old) by MadMan (Chicago, IL, USA)   |   | |
