Thread Number: 36786
no serial # ? |
Post# 393546   6/19/2018 at 20:49 (2,134 days old) by jrdavis (oklahoma)   |   | |
whats up with that?
Post# 393548 , Reply# 1   6/19/2018 at 21:12 (2,134 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 393553 , Reply# 2   6/19/2018 at 22:16 (2,134 days old) by jrdavis (oklahoma)   |   | |
Post# 393560 , Reply# 3   6/20/2018 at 01:11 (2,134 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 393572 , Reply# 4   6/20/2018 at 07:35 (2,134 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 393616 , Reply# 5   6/20/2018 at 19:56 (2,133 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 393648 , Reply# 6   6/21/2018 at 11:41 (2,133 days old) by Phaeton (Los Angeles )   |   | |
Hello jrdavis and all,
You are all correct. On my 541 the ID Plate had the serial number scratched out and changed. I believe none were changed by the Hoover Factory as when they rebuilt them they put the green ID Plate with a new serial number. Also the independent vacuum shops could order blank original style ID Plates. On the 541 and I think possibly other models by removing the rear wheel assembly which is attached to the base by 4 screws you will find the true serial number as seen in the last picture. Just take caution not to lose any of the small parts to the belt cover latch. I also have a Hoover Factory Rebuilt 541 and the true serial number was under the rear wheel assembly. This was also the case with my Hoover Factory Rebuilt 105, these only have 2 screws holding the rear wheel assembly on. On the 543 and 700 the rear wheel assembly is riveted and would not have a serial number under it as the model and serial number are both on the underside of the casting. Thank you for looking and I hope this was of some help to all of you. Pete |
Post# 393649 , Reply# 7   6/21/2018 at 12:42 (2,132 days old) by jrdavis (oklahoma)   |   | |
Post# 409347 , Reply# 8   5/11/2019 at 10:30 (1,809 days old) by Phaeton (Los Angeles )   |   | |
