Thread Number: 36580  /  Tag: 80s/90s Vacuum Cleaners
Electrolux Corporation L-Shaped Power Nozzle Motor Replacement
Post# 391758   5/9/2018 at 21:57 (2,149 days old) by Paul (USA)
I need to replace the motor in my Electrolux Special Edition 7B "Omni-Flo Automatic" power nozzle. The model is 6700-81, it's a Type A, and the letter code is PAFC.
I've checked online using the model number with other information, but have found nothing.
Do all Electrolux Corporation's L-Shaped power nozzles for cylinders & canisters use the same motor model?
Also, let me know if some replacement motors are better than others.
Post# 391833 , Reply# 1   5/11/2018 at 10:07 (2,148 days old) by eurekastar (Amarillo, Texas)
eurekastar's profile picture
I think any of the aftermarket motors that you see on the net will work. I've never used one; however, they appear to be missing the two mounting lugs at the pulley end that the older motors had. The screw mounts in the middle of the motor appear to be the same.
CLICK HERE TO GO TO eurekastar's LINK
Post# 391963 , Reply# 2   5/14/2018 at 19:03 (2,145 days old) by Paul (USA)
Thanks for the info. & link, Bill.
