Thread Number: 36552
D80 2..0 |
Post# 391474   5/2/2018 at 23:07 (2,179 days old) by Lesinutah (Utah)   |   | |
Hey
I have mentioned recently my rebuilding 2 d80s. It was 2 days ago i finally had first one all together and finished. I thought it was finished but i was wrong. I turned it on it worked but didnt sound right. It felt like the fan was hitting something. It turns out armature fan sas grazing 2 wires from headlight in motor housing. I fixed nicks in wires using heat shrink. I also fixed it so the wires wouldn't get hit again. The problem is wires staying in safety switch. I took the back cover off the safety switch. |
Post# 391477 , Reply# 1   5/2/2018 at 23:22 (2,179 days old) by Lesinutah (Utah)   |   | |
So you see first pic is safety switch and second pic is copper piece from safety switch. I was wondering if i could pull out copper tabs and solddr wires to them and reinsert in safety switch. I have back ill put back on just gluing it back together.
2nd question on power switch it has 3 ground slots and 3 white slots. Couldn't i take all 3 grounds solder together while soldering a 4th wire. It would be 3 soldered and end result 1 wire coming out. It would combine all greens to 1 wire. I would do same for 3 whites. So instead of using all 6 slots i would use just 2. The reason behind this is only 2 wires could come loose. It has 2 slots for power wires. One power is from headlight power the other goes to carbon brush holders and holds in carbon brushes. I dont know why anpower is ran to carbon brushes but combining the 2 could arc something out. So any feedback would be appreciated. Les |
Post# 391690 , Reply# 2   5/8/2018 at 14:39 (2,173 days old) by Lesinutah (Utah)   |   | |
Post# 391719 , Reply# 3   5/9/2018 at 00:10 (2,173 days old) by Lesinutah (Utah)   |   | |
Post# 391720 , Reply# 4   5/9/2018 at 00:33 (2,173 days old) by Lesinutah (Utah)   |   | |
