Thread Number: 36428
My 1st True Classic Deluxe Convertible!!!! |
Post# 390449   4/13/2018 at 20:45 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
Hi guys, well once again I got another vacuum for my collection and this of course is a vacuum collectors favorite! A Hoover Deluxe Convertible U4009. Got this from eBay for $75 + free shipping, it used to cost $95 but somehow it was $20 off, sweet deal! It needs a little clean up but it sounds pretty good, nothing worn out. I hope y’all enjoy the pics of my member of my collection!
Post# 390450 , Reply# 1   4/13/2018 at 20:46 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
Love the shape of the hood!
Post# 390451 , Reply# 2   4/13/2018 at 20:47 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
Nice retro bag design!
Post# 390453 , Reply# 3   4/13/2018 at 20:52 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
So far there’s only 2 problems, one the handle grip comes off when pushing and pulling the vacuum so if anybody had this problem before what should I use to make it stay in place? And lastly, it’s kinda hard to explain the height adjustment doesn’t want to stay in place when it moves around a bit so hopefully there’s a way to fix that.
Post# 390454 , Reply# 4   4/13/2018 at 20:53 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
Bottom is in good shape too!
Post# 390455 , Reply# 5   4/13/2018 at 20:57 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
It also features the classic old style tool converter slide in design, I would love to have the old style hose attachment that stretches, not the tufflex one. The serial number is 0148666, maybe ‘73 or to ‘75?
Post# 390456 , Reply# 6   4/13/2018 at 20:58 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
Brushroll and belt are in very good shape too!
Post# 390457 , Reply# 7   4/13/2018 at 21:00 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 390460 , Reply# 8   4/13/2018 at 21:16 (2,202 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 390462 , Reply# 9   4/13/2018 at 21:43 (2,202 days old) by MadMan (Chicago, IL, USA)   |   | |
Noice.
Idk what the common consensus is around here for the handle. But my recommendation would be to smear some silicone around the metal tube, and some inside the rubber grip, slip it on, clean it up, let it dry overnight. It should hold up to use, without really being 'permanent' because you should be able to pry it loose if you ever needed to. It will be messy though, have a lot of paper towels on hand. Alternatively, you can usually leave all the extra silicone there without touching it at all, and when it's dry, it usually peels away no problem. |
Post# 390473 , Reply# 11   4/14/2018 at 08:47 (2,202 days old) by Oreck_XL (Brooklyn, New York 11211)   |   | |
Post# 390477 , Reply# 12   4/14/2018 at 10:43 (2,202 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Great machine.... a nice addition to your collection.
If people ever needed to/wanted to REMOVE that handle grip, they'd soak it in hot water, loosened the glue, and off came the grip. IF you don't want/need to ever have to remove it, you can apply some glue to the inside of the grip, slide it onto the handle, and let it dry. I did that to one of my Dial A Matics. Like new today! As far as the height adjustment: perhaps the curve in the lever is worn. It sometimes happens to the handle release pedal, too. You may: replace it, OR try getting a little round file and file the concave curve a little deeper, so it will 'grab' the wheel. That'll clean up very nicely. Good luck on the tools. You MUSTY have them. Although "ultraflex" was great, my favorite is still "Tufflex". Happy Hoovering. John |
Post# 390491 , Reply# 13   4/14/2018 at 18:52 (2,201 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 390492 , Reply# 14   4/14/2018 at 19:25 (2,201 days old) by Real1shep (Walla Walla, WA)   |   | |
I tried Gorrila glue on a tool handle.....lasted a couple of yrs then came off like nothing was ever on there.
Kevin |
Post# 390493 , Reply# 15   4/14/2018 at 19:47 (2,201 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 390496 , Reply# 16   4/14/2018 at 20:51 (2,201 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 390501 , Reply# 18   4/14/2018 at 22:12 (2,201 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Superglue works just fine. I'm not familiar with this "pliobond". It may work well too.
You'll not find Elmer's helpful. As I mentioned earlier, superglue did the trick on my stellar Dial A Matic. Several people can give equally useful advice in this forum,one of the very reasons for said forum. For most of us, Crazy glue, Super glue, etc are readily available. Where does one find this wonder adhesive called "Pliobond"? Again, best of luck with your fabulous new Hoover Convertible "Deluxe". Upon consulting with the best expert in all things HOOVER, AND upon closer inspection of your photo, it appears that the spring is not connected to the axle, resulting in a floppy axle. And, who needs a floppy axle? No one. To remedy this, simply reconnect the spring to the axle and your height adjustment problems are a thing of the past. Now, we must be on the lookout for your "tools". |
Post# 390507 , Reply# 19   4/15/2018 at 01:08 (2,201 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 390508 , Reply# 20   4/15/2018 at 01:22 (2,201 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 390510 , Reply# 21   4/15/2018 at 02:45 (2,201 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 390539 , Reply# 23   4/15/2018 at 19:40 (2,200 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Gorilla Glue needs to have the two parts where the glue will be applied to be moistened before gluing, and held in place overnight. Obviously, like any glue, you cannot glue two parts together that will undergo stress, and parts that are not porous.
I used it to re-glue a clay flowerpot back together that shattered into about 60 pieces and then used a hobby knife to scrape off the foam "overspray" and rubbed a scrap piece of clay into the glue marks and although it's obvious it's been reglued, it holds together nicely and has had about 60 lbs of dirt in it for over a year and not had any issues. I don't see any need that would arise where you would have to get into the inside of the handle so I'd just glue the rubber on there. Look for a glue that can bond to nonporus surfaces like polished metal, and also that will not eat away rubber. I know your off the shelf superglue can eat through rubber due to the chemical composition of it. I am not sure if it will work with this, but with some types of rubber you can just heat it up in a bowl of water in the microwave for a few seconds and it will shrink a bit, which you can slide it back onto the handle no glue needed. It would be worth looking into if nothing else works. |
Post# 390543 , Reply# 24   4/15/2018 at 21:15 (2,200 days old) by Real1shep (Walla Walla, WA)   |   | |
I used Gorilla glue on a tool handle...break over bar. Lasted about a yr of use and came off like it had never been glued and surprisingly almost no residue (where did it go?). Plastic/rubber on metal.
Kevin
Post# 390546 , Reply# 25   4/16/2018 at 02:56 (2,200 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
I had to google what a "break over bar" was, and I will say that a year of use is a great lifetime for gluing something like that! Glue is never permanent, especially on tools, as they go through a lot of flexing and shifting in their use that it will break the glue bond, it's only meant for temporary fix until you can replace it. A socket adapter takes a lot of torque and twisting, no glue would hold up to that, it's an instance where you'd just have to replace it rather than keep re-gluing it all the time. Those things are really cheap, I think the bottle of glue costs more than a new tool, lol
Post# 390552 , Reply# 27   4/16/2018 at 09:56 (2,200 days old) by kirbyvertibles (Independence, KS)   |   | |
Very nice!!
These came out somewhere between 73-75 ish 26,000 off the line means it's fairly early production I would say but I am NOT an expert. If you look up in the forum search and type in maybe convertible list you will pull up a post with a list of all the metal Convertibles and their info That white design on the bag is called a Filigree pattern. |
Post# 390562 , Reply# 28   4/16/2018 at 15:01 (2,199 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 390603 , Reply# 29   4/17/2018 at 10:45 (2,199 days old) by kirbyvertibles (Independence, KS)   |   | |
Post# 390766 , Reply# 30   4/20/2018 at 09:10 (2,196 days old) by Gj3476 (Prosper,TX)   |   | |
Yesterday I washed the hood and vinyl bag in the bathtub with dawn soap and my moms homemade cleaning spray, and shined up the hood with mother’s polish cream and it looks not bad. And I used super glue for the handle grip, and it also needed a new belt. I still haven’t figured out the problem with the height adjustment.
Post# 390768 , Reply# 31   4/20/2018 at 09:35 (2,196 days old) by kirbyvertibles (Independence, KS)   |   | |
