Thread Number: 36255
Dial a Matic 1149 lives again.......but one lil problem. |
Post# 388775   3/22/2018 at 21:11 (2,219 days old) by Gj3476 (Prosper,TX)   |   | |
Hi everybody! Y’all remember my ‘73 Dial a Matic 1149 I posted back in October and mentioned that the vacuum doesn’t turn on at all, well that because the original motor was damaged and a very good friend I talk to, Damien aka 2011hoover700 gave me a Dial a Matic motor he had after I gave him white plastic Hoover wands and a Eureka Whirlwind hose as a gift! So when the motor arrived, I started putting the motor together and plug it in and it works, but here’s the bad news, the suction is not strong at all, it’s very weak. The motor sounds and works like normal but it’s suction that is having suction problems. So I need some help from y’all Dial a Matic fans, do y’all have this type of problem before? If you do, please tell me. But one thing I’m grateful that my DAM has a motor that runs.
Post# 388776 , Reply# 1   3/22/2018 at 21:12 (2,219 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 388777 , Reply# 2   3/22/2018 at 21:13 (2,219 days old) by Gj3476 (Prosper,TX)   |   | |
To prove the vacuum runs, here’s the brushroll spinning.
Post# 388778 , Reply# 3   3/22/2018 at 21:16 (2,219 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 388782 , Reply# 4   3/22/2018 at 21:43 (2,219 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 388798 , Reply# 5   3/23/2018 at 01:11 (2,219 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 388800 , Reply# 6   3/23/2018 at 05:29 (2,219 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 388810 , Reply# 7   3/23/2018 at 08:57 (2,219 days old) by kirbyvertibles (Independence, KS)   |   | |
If the motor sounds fine then it's going to be doing what it's supposed to do. If it has very high pitched whine that unbearable then there's a good chance the fans are clogged but I doubt this is the issue. I bet you just have a seal problem somewhere. You might try getting some weather strip of some kind (not too thick) and put on the bag compartment for better seal. Or could be losing air around the motor housing?
Post# 388822 , Reply# 8   3/23/2018 at 12:36 (2,219 days old) by bnsd60m9200 (Akron OH)   |   | |
check the black rubber band gasket around the motor itself. NOT the black end that holds the motor in place. if you put in the wrong place upon reinstall it will have very poor airflow. did this by accident with my u5015 after i rebuilt it. had to take the whole damn machine apart to figure out that was the issue.
Post# 388828 , Reply# 9   3/23/2018 at 13:07 (2,219 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
