Thread Number: 3619
Do these brushes look OK?
Post# 40691   5/17/2008 at 19:32 (5,820 days old) by camelotshadow (Valley Village)
just totally cleaned the inside of my d33 filter queen
has all motor gaskets & secondary off & cleaned
wiped carbon from motor
brushed dust & blew it out
its all clean now
wondering why the brush on the right has a different appearance
color is sort of like it has a bit or corrosion.
Its the same motor as the other I took apart
same numebers on top
but this unit serial # starts D5...
power nozzle has a 78 sort of dat so think its a 78
Post# 40698 , Reply# 1   5/17/2008 at 19:52 (5,820 days old) by camelotshadow (Valley Village)
this is the model 31 filter queen
these motors look same
but the 33 motor was cleaner
I've cleaned this one as much as I can.
Brushes look similar to the other
hard to see but think even this motor looks better than the 86 rusty one
so I might just switch the metal top & pedal switch into this one & it will be whole. Can then slowly find the needed parts for the newer model as I clean that badly rusted motor
so I figure that one had to have sucked up water
Post# 40700 , Reply# 2   5/17/2008 at 20:03 (5,820 days old) by camelotshadow (Valley Village)
maybe the brushes are down?
Looks like less on the newest motor & added a power cord to.
Heres the 1986 brushes
look thicker
if the other is getting to a end
guess they should be changed?
that shouldn;t be too hard...
