I have several canisters that have European power nozzle plugs on the hose, these receptacles are slightly larger than the plug commonly used on United States machines. I'm wondering if anyone knows if an adapter is available or if one could be made to convert this plug to the smaller plug that is common on United States electric hoses. I have several power nozzles with United States plugs that I would like to use with these machines. They are the Hyla, sirena and Roboclean. Adapters are widely available to go from the 35 mm hose size to 32 mm, but I have not found an adapter to change the electric plug. I think the Miele canisters also use the larger plug that I am trying to convert. Interestingly, the Riccar universal power nozzle does fit these machines, I guess the plug on this nozzle is slightly larger.
Mike
