Thread Number: 35921  /  Tag: 50s/60s/70s Vacuum Cleaners
Gasket material on Hoover bottom plate
Post# 385268   2/2/2018 at 18:52 by hooverU4089 (CT)
I need to restore the gasket material that seals the metal bottom plate to the nozzle of an older Convertible as it is starting to come off. What are some products I should try?
Post# 385277 , Reply# 1   2/2/2018 at 20:25 by vacuumlad1650 (Chicago Suburbs)
vacuumlad1650's profile picture
A Silicone bead works perfectly
Post# 385280 , Reply# 2   2/2/2018 at 21:14 by pr-21 (Middletown, OH)
pr-21's profile picture
Kirby makes a rubber gasket material for the older models, like the classic etc. You can find it on Ebay. I have
used it on hoovers, vintage vacuum cleaner rug plates etc. It can be trimmed or cut with a razor knife etc.
It has worked well for me. One side has an adhesive side, just make sure the surface you put it on is pretty clean,
by scraping the old off first.
PR-21
Bud
Post# 385348 , Reply# 3   2/3/2018 at 18:17 by hooverU4089 (CT)
Thanks,
I applied some 24-hour-cure multi purpose silicone after cleaning the residue with a wire brush. I'll see what happens.
Vacuumland home
Discuss-o-Vac Forums
Today's Vacuum of the Day
