Thread Number: 35722
Electrolux Motor Question |
Post# 383421   1/1/2018 at 23:06 (2,305 days old) by eurekastar (Amarillo, Texas)   |   | |
I have an Electrolux Olympia One that has that typical musty motor smell. I want clean the fans but I'm not certain how to stabilize the armature in order to remove the nut on the fan end of the motor. I'm sure it's something simple but I've never serviced an Electrolux motor before. Thanks for any help and advice!
Post# 383423 , Reply# 1   1/2/2018 at 00:00 (2,305 days old) by Real1shep (Walla Walla, WA)   |   | |
To separate the armature from the fan stage you have to gently separate the fan stage at the seam. Make a mark with a Sharpie on both side of the seam, so you can realign like it came. Once you get that apart you'll see the nut to release the armature.
Kevin |
Post# 383443 , Reply# 4   1/2/2018 at 11:26 (2,305 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 383454 , Reply# 5   1/2/2018 at 15:07 (2,304 days old) by suckolux (Yuba City, CA)   |   | |
Post# 383468 , Reply# 6   1/2/2018 at 21:07 (2,304 days old) by eurekastar (Amarillo, Texas)   |   | |
Nathan, thanks for your help! It was simple to open. I was just a little worried about putting too much pressure on the fan. But it opened right up. It's all cleaned out and smells like it should!
