Thread Number: 35722  /  Tag: 50s/60s/70s Vacuum Cleaners
Electrolux Motor Question
Post# 383421   1/1/2018 at 23:06 (2,305 days old) by eurekastar (Amarillo, Texas)
eurekastar's profile picture
I have an Electrolux Olympia One that has that typical musty motor smell. I want clean the fans but I'm not certain how to stabilize the armature in order to remove the nut on the fan end of the motor. I'm sure it's something simple but I've never serviced an Electrolux motor before. Thanks for any help and advice!
Post# 383423 , Reply# 1   1/2/2018 at 00:00 (2,305 days old) by Real1shep (Walla Walla, WA)
To separate the armature from the fan stage you have to gently separate the fan stage at the seam. Make a mark with a Sharpie on both side of the seam, so you can realign like it came. Once you get that apart you'll see the nut to release the armature.
Kevin
Post# 383430 , Reply# 2   1/2/2018 at 06:32 (2,305 days old) by Electrolux-dude (Canyon, TX)
I can help you
Hello EurekaStar. I live in Amarillo TX. Give me a call at 806-400-2999. If you would like to bring the vacuum by I can help you service and clean the motor. Olympias are great vacuums and I have serviced hundreds of them.
Nathan L. Thomas
Electrolux Dude
Post# 383432 , Reply# 3   1/2/2018 at 08:25 (2,304 days old) by Real1shep (Walla Walla, WA)
The Oly One should have the Super J motor inside; longer armature, bigger (more expensive) brushes. Electrolux USA retooled their plant just to feature this motor. Also, they had a fire on their line and had to outsource the armature, so a certain Super J serial # run had motor problems. Elux took care of every unit that was troublesome under warranty. Those units usually have sticker on the tank that says 'Five Year Warranty'.
I think it was worked out by the time the Silverado and Oly One came along.
Kevin
Post# 383443 , Reply# 4   1/2/2018 at 11:26 (2,304 days old) by eurekastar (Amarillo, Texas)
Thanks!
Thanks Nathan! I'll give you a call later today. It will be good to have an expert tutor!
Post# 383454 , Reply# 5   1/2/2018 at 15:07 (2,304 days old) by suckolux (Yuba City, CA)
My Silverado says five year warranty
Post# 383468 , Reply# 6   1/2/2018 at 21:07 (2,304 days old) by eurekastar (Amarillo, Texas)
Success!
Nathan, thanks for your help! It was simple to open. I was just a little worried about putting too much pressure on the fan. But it opened right up. It's all cleaned out and smells like it should!
