Thread Number: 35588
/ Tag: Small Appliances
Problem with Farberware cooktop |
Post# 382375   12/8/2017 at 23:24 (2,322 days old) by fan-of-fans (USA)   |   | |
I found a Farberware cooktop at the flea market. After I got it home, I noticed the plastic cover over the box where the wires connect to the power cord was a little melted! I decided to have a look inside and didn't really see any damage, but the clamp on the power cord was really tight and seemed to have smashed the cord.
I am wondering if the power cord could have overheated due to being compressed too much, but the cord doesn't seem to be melted. If it did overheat it would seem it would have melted the cord clamp as well. I am wondering if I should cut the crushed part of the cord off and reconnect it to be safe, but I don't have the proper crimp connectors and they are probably special high temp ones anyway, given the wiring is cloth. Maybe something else caused the melting of the cover? I did plug the unit in, the "power to" light came on and I turned on both burners and they worked fine, as did their indicator lights, the cord did get a little warm but not hot. The picture of the cord, you can see the gray stripe is where it got compressed by the clamp. |
