Thread Number: 35479  /  Tag: Recent Vacuum Cleaners from past 20 years
Fantom Vacuum Tips & Tricks (Vol 1)
Post# 381344   11/14/2017 at 22:07 (2,344 days old) by FantomTechGuy (US)
fantomtechguy's profile picture
Greetings!
FantomTechGuy here today to bring you something else besides updates. (More on the way soon) This will be a mini series I will post on here on various Tips & Tricks that you can preform on your Fantom Vacuums to make them last longer, make them look better and overall make them last. So let's get started with the list!
Do you want to make your Fantom more shinny and near new but don't have the time or money to get professional products to do the job? Well I've got a trick up my sleeve!
Just grab some regular Furniture Polish! Regular Lemon Pledge is perfect for bringing the shine back into the plastic. It is very gentle on the plastic and logos and makes a perfect way to tidy up your Fantom Collection!
Do you want the belt on your Fantom to last longer? Just place your belts in the crisper section of your fridge and the belts will last longer! Here is the science;
By placing the belts in the fridge, the rubber can stay at a normal state. Which means that the belt will not warp because of temperature changes!
And Finally, do you want your HEPA filter to last longer? Simply grab some Cut-To-Fit carbon foam pre-filter! Simply measure your HEPA filter, cut and place back into the housing! By doing this, you don't effect the performance of the vacuum and less debris gets trapped into the filter! But only do this to a new filter. Do not reuse a soiled filter, as that can cause a smell or pollute the air.
(I am not to be held responsible if you attempt these and misuse causes damage to your Fantom)
Thanks for reading and see you in a few for a new update! Stay tuned!
-FantomTechGuy
