Thread Number: 35320
Hoover Windtunnel twin chamber |
Post# 382276 , Reply# 1   12/7/2017 at 09:42 (2,330 days old) by carolinaguy1996 (Candler, NC)   |   | |
The bagless machines are crap coming out of our asses. The bagged machines tend to last longer. |
Post# 382284 , Reply# 2   12/7/2017 at 13:36 (2,330 days old) by bagintheback (Flagstaff, Arizona)   |   | |
Is it one of models with the power switch on the handle? Those are actually an extension of a plastic rod that mechanically flips a rocker switch right below where the handle is screwed in. Overtime the rod can become slightly bent and lose ability to fully flip the power switch.
Your machine might have that problem. It can still move the switch, but maybe only a quarter or half way; not enough to bring the switch fully into the on position. That may be why it will come on for a second and power off. I've had this issue before on one of mine. There should be two long screws on the back on the handle, and attached nuts in the front behind the dust cup. Once you pull out the handle assembly, the rocker switch will be there on the body. If you flip it and it comes on, then the plastic rod is your problem. The cut on the cord doesn't look that deep, but definitely much some electrical tape around it. I hope I was able to help! |
