Thread Number: 35281
Hoover convertible high performance making a weird noise |
Post# 379655   10/13/2017 at 06:04 (2,359 days old) by Gj3476 (Prosper,TX)   |   | |
Hello convertible fans! I have a late 80's/early 90's Hoover convertible high performance that I got from eBay almost a year ago and when I got it, it worked pretty good till in December when I was using it it somehow made a weird lawn mower like noise and I was like "What!?",so I thought the belt broke and got caught on the fan but it wasn't it and I thought the fan might have got broken but I checked with a flashlight and it wasn't it either,so I don't know I haven't been using it for almost a year and I hope someone knows the problem because I have know idea.
Post# 379657 , Reply# 1   10/13/2017 at 06:22 (2,359 days old) by Firebirdman55 (Owensboro Kentucky)   |   | |
Post# 379676 , Reply# 2   10/13/2017 at 11:41 (2,358 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 379747 , Reply# 3   10/14/2017 at 13:26 (2,357 days old) by Phaeton (Los Angeles )   |   | |
Post# 379757 , Reply# 4   10/14/2017 at 15:39 (2,357 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 379759 , Reply# 5   10/14/2017 at 16:08 (2,357 days old) by Phaeton (Los Angeles )   |   | |
Hello,
Yes I understand, and to be honest I do not remember how the hood is removed LOL. If it were the Classic Convertible of the 60's & 70's I could tell you in a flash. I know I removed that style of hood many times at the shop. I believe it has 2 phillips/cross screws on the bottom that need to be removed. A picture of the bottom would help my old brain remember or better yet a Vacuumland Member jumping in and telling how to remove the hood. Sorry I was not able to help, Pete This post was last edited 10/14/2017 at 17:26 |
Post# 379771 , Reply# 7   10/14/2017 at 19:32 (2,357 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 379783 , Reply# 8   10/14/2017 at 23:44 (2,357 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 379784 , Reply# 9   10/14/2017 at 23:46 (2,357 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 379786 , Reply# 10   10/15/2017 at 01:03 (2,357 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 379804 , Reply# 11   10/15/2017 at 15:50 (2,356 days old) by TheSpiritOf76 ()   |   | |
This is what I am talking about.
Post# 379810 , Reply# 12   10/15/2017 at 18:25 (2,356 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 380896 , Reply# 13   11/7/2017 at 23:25 (2,333 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 381847 , Reply# 14   11/26/2017 at 21:59 (2,314 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 381851 , Reply# 15   11/26/2017 at 23:25 (2,314 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 381852 , Reply# 16   11/27/2017 at 06:47 (2,313 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
There are two Fillips Head screws on the underside of the machine. Take those out. Set the height to HIGH and tilt the handle back 1 setting. Lift the hood off.
Disconnect the belt, then undo the 4 screws that hold the bottom of the motor to the base. Lift the motor and the fan is exposed. Use a big flatblade and while holding the Fan, turn the belt pulley CLOCKWISE to remove it. |
Post# 381878 , Reply# 17   11/28/2017 at 01:42 (2,313 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Gabriel,
Your Hoover High Performance Convertible is a model U4727-900 if I am right, right? Anyway, here's a parts diagram and list covering this machine as taken from my big HESCO Hoover Repair Parts Catalog (dated June 1996). ~Ben |
Post# 381952 , Reply# 18   11/29/2017 at 21:18 (2,311 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 381959 , Reply# 19   11/29/2017 at 23:01 (2,311 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 381972 , Reply# 20   11/30/2017 at 15:37 (2,310 days old) by Gj3476 (Prosper,TX)   |   | |
Well I took the vacuum apart and I’m trying figure out if I’m actually doing this right? I didn’t use instructions surprisingly.
Post# 381973 , Reply# 21   11/30/2017 at 15:39 (2,310 days old) by Gj3476 (Prosper,TX)   |   | |
Never moind!! 😜👍
Post# 381983 , Reply# 22   11/30/2017 at 17:46 (2,310 days old) by Gj3476 (Prosper,TX)   |   | |
Well the new Hoover fan has finally arrived and I’m having a little hard time right now. I’m trying to figure out how I’m going to replace the old with the new. The fan bar is supposed to screw off.
Post# 381990 , Reply# 23   11/30/2017 at 19:30 (2,310 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 381995 , Reply# 24   11/30/2017 at 20:42 (2,310 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 381997 , Reply# 25   11/30/2017 at 21:17 (2,310 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 381998 , Reply# 26   11/30/2017 at 21:49 (2,310 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
It will take some substantial force.
Vice grips are pliers that stay locked in whatever you clamp them on with spring tension. If you still can't get it while holding the fan, push a small screwdriver in this hole (backside of motor) to lock the Armature shaft.
Post# 381999 , Reply# 27   11/30/2017 at 21:58 (2,310 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 382010 , Reply# 28   12/1/2017 at 06:27 (2,309 days old) by Gj3476 (Prosper,TX)   |   | |
Vacuumlad1650, I did that little trick you told me about and I got a little problem.☹️ I hope this won’t affect the vacuum’s performance. And I still haven’t got the frickin fan out.
Post# 382011 , Reply# 29   12/1/2017 at 06:30 (2,309 days old) by Gj3476 (Prosper,TX)   |   | |
I used a little bit of gorilla tape.
Post# 382012 , Reply# 30   12/1/2017 at 06:39 (2,309 days old) by Gj3476 (Prosper,TX)   |   | |
I got it!
Post# 382014 , Reply# 31   12/1/2017 at 07:10 (2,309 days old) by Gj3476 (Prosper,TX)   |   | |
Well after of struggling n struggling, I got him or her fixed! It works! Yay me!!!👏👏👏👏👏👏👏👏👏
Post# 382015 , Reply# 32   12/1/2017 at 07:47 (2,309 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 382018 , Reply# 33   12/1/2017 at 08:26 (2,309 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 382045 , Reply# 34   12/1/2017 at 20:16 (2,309 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 382051 , Reply# 35   12/1/2017 at 20:40 (2,309 days old) by Gj3476 (Prosper,TX)   |   | |
