Thread Number: 35211  /  Tag: 50s/60s/70s Vacuum Cleaners
Electrolux Model L
Post# 379161   10/2/2017 at 19:19 (322 days old) by Keither (California )
keither's profile picture
My Electrolux Model L ! Performed a little cosmetic maintenance on it and I also repaired the air leaks in the hose.
Post# 379175 , Reply# 1   10/3/2017 at 09:17 (322 days old) by Louvac (A)
Super Nice!
I love that model for some reason-it's simple, well made, and it's a great cleaner!
It might have something to do with the fact that it's also blue! If the machine's blue...I gotta have it!
Nice job! Where did you find it?
Post# 379180 , Reply# 2   10/3/2017 at 11:23 (322 days old) by Keither (California )
Hey thanks. I found it on Craigslist.
Post# 379293 , Reply# 3   10/5/2017 at 15:10 (320 days old) by Paul (MN)
Looks great, Keith! You were fortunate to get the color-matching Rug Washer with it, too. That's not common.
Its hose suggests that it was made from 1971 to 1975 (unless it's a replacement). Going by the users manuals, the first iteration of teal blue Model Ls, 1968 to 1969, had the gooseneck-grip standard hose with or without the pigtail cord; the second iteration, 1969 to 1971, had a pistol-grip standard hose or power hose with electrical coupling. The third iteration, 1971 to 1975, had the gooseneck-grip standard hose or power hose with pigtail end, like yours.
Btw, the 1969 to 1971 power hose with the electrical coupling was reintroduced with a revised pistol-grip in late 1975. From that time to 1982 four hoses with pistol-grips were offered: the power hose with electrical coupling for the 1205 or 1401; the power hose with pigtail end for the Model L; the standard hose for any cleaner, and the standard vinyl hose with 3-wire cord for the Model CB.
I've never seen a standard hose in the gray colors (Silverado-era) or the later braided hoses of different colors, so I'm thinking that from 1982 to 1993 these braided hoses were available: the pistol-grip power hose with electrical coupling, the standard vinyl with 3-wire cord and metal coupling for the Models CB & CB2000, beginning in 1986 the standard vinyl hose with plastic coupling for the L-shaped uprights, and beginning around 1987 the uprights' standard vinyl hose with plastic coupling & pigtail cord for the Sidekick (adapter for cord plug-in to cleaner needed until 1991). I'm unsure what type(s) the central vacs have used, but Electrolux Corp. introduced them in 1986.
1993 marked the retirement of the braided hoses and the introduction of the PVC (polyvinyl chloride) hoses (or was that earlier with the central vacs?). The pistol grip continued being used with the budget models, CB2000, and uprights; the gas pump-grip with on/off switch was introduced with the Epic 6500SR, model 1762; and the gas pump-grip with push button electronic suction and on/off controls was used with the Renaissance, model C104A from 1994 to 1995. The handle controls were revised with the Renaissance C104H in 1995, and a suction slider control replaced the style with push buttons on the Epic 8000's in 1997. The Model CB2000's standard hose with the 3-wire cord was retired in 1999 along with the cleaner. I don't know about all the changes since 1999. Note: If you're trying to get original-matching white PVC hoses with all-white grips, look for the colored line tracer in the hoses.
Sorry for digressing, but I got on a roll and hope it will help you as you build your vac collection. One more thing, you can use a Sidekick with your Model L's hose; just get a 6" pigtail cord. Also, you can contact Aerus to request users manuals for the Model L and Rug Washer. In case you didn't know the Model L was manufactured in these color schemes: ivory w/teal green trim--1963 to 1966; tan w/ivory trim--1966 to 1968; teal blue & ivory trim--1968 to 1975; and honey gold w/ivory trim--1975 to 1979; and the Rug Washer accessory was available from 1962 to 1987 in several color schemes that matched the vacuum cleaners sold during each period. Have fun using your new acquisitions.
Post# 379306 , Reply# 4   10/5/2017 at 20:37 (319 days old) by Paul (MN)
Hi again, Keith,
In eBaying, I discovered that I'd forgotten that there was a fourth iteration of the teal blue Model L from 1974 to 1975 with the white pigtail-end hose with teal/gold/teal tracers and the model PN-2* power nozzle like the 1205 Jubilee cleaner's.
Also, in looking at your photo again, I wondered if you knew that the cord is meant to be wound on the chrome cord wrap, aka a "halo", and the end is placed in the cord clip by the back of the handle (see photo #2).
*introduced in 1973, according to the users manual
Post# 379308 , Reply# 5   10/5/2017 at 21:01 (319 days old) by vacuumlad1650 (Chicago Suburbs)
vacuumlad1650's profile picture
There was a Gold model L. I'm assuming that one has a replacement hose.
Post# 379385 , Reply# 6   10/7/2017 at 15:30 (318 days old) by Keither (California )
Thanks for all of the feedback guys.
Post# 380392 , Reply# 7   10/28/2017 at 19:54 (296 days old) by lux14 (Leawood Kansas)
Hi Keith..... Hope all is well. How did you repair your hose? Best! Richard.
Post# 380446 , Reply# 8   10/30/2017 at 18:43 (295 days old) by Keither (California )
Hi Richard ! I employed the Plastidip technique! It works well!
Post# 380451 , Reply# 9   10/30/2017 at 21:53 (294 days old) by lux14 (Leawood Kansas)
Thanks Keith....I have used it as well. I agree. I buy the can version take the pistal end off and coat the inside of the hose and hang it so the excess runs out. I have had pretty good luck. You just have to roll the hose on the ground to ensure you get the plasti dip evenly distributed. I was wondering if you might have found a better technique. :-) I love the original weaved hoses. Just love using them! Hope all is well my friend!!!!
Post# 380455 , Reply# 10   10/30/2017 at 22:43 (294 days old) by Keither (California )
The Plastidip process has proven to be the for sure remedy for a leaking fabric hose! I employ the same method as you do Richard. I like using them too! The machines looks so nice when the original attachments are used🙂 I hope that your doing well! 🙂
Post# 380885 , Reply# 11   11/7/2017 at 22:12 (286 days old) by Paul (MN)
What do you guys mean by "the can"--liquid or spray? I've used the liquid with good results but am wondering if the spray can works as well since I'm out of the liquid and don't want to buy another gallon for just one or two hoses I didn't do.
Post# 381076 , Reply# 12   11/10/2017 at 15:08 (284 days old) by keither (California )
Paul I only use and would only recommend using the liquid. I dont recall mentioning using the spray.
Post# 381104 , Reply# 13   11/11/2017 at 00:42 (283 days old) by Paul (MN)
Ok, Keith.
My research found that Plasti Dip is available in liquid in 22 oz. cans, which is all I need at this point. I already used up a gallon of Rubber Dip.
I am going to get the clear (#12219).
Post# 381161 , Reply# 14   11/11/2017 at 20:10 (282 days old) by keither (California )
Yeps...I would prefer the clear over the black if it were available here at Home Depot. I could order on line though.
Post# 381291 , Reply# 15   11/14/2017 at 00:23 (280 days old) by Paul (MN)
You can also order online through Ace Hardware and have it delivered to a store near you for free.
Post# 381463 , Reply# 16   11/17/2017 at 01:42 (277 days old) by keither (California )
Thanks Paul :-)
Vacuumland home
Discuss-o-Vac Forums
Today's Vacuum of the Day
