Thread Number: 35100
Very serious question.....Vacuum Circuit boards |
Post# 378293 , Reply# 1   9/12/2017 at 09:23 (2,411 days old) by crazykirbydude (Lexington, KY)   |   | |
The circuit boards serve two functions, one is the make the unit look "cutting edge" and "technologically advanced" in the store. The second function is to crap out just after the warranty expires. That way you have to buy a new one. If the board is shot, just go ahead and chuck everything in the trash. It's not worth the frustration.
Post# 378312 , Reply# 3   9/12/2017 at 15:03 (2,411 days old) by fantomfan57 (Central Texas)   |   | |
Thermal shut off....that is it. Unless I can wire in another device, there will always be that danger. What did vintage machines do for that potential danger? Perhaps a one time inline fuse. Your thoughts? |
Post# 378317 , Reply# 4   9/12/2017 at 20:09 (2,411 days old) by human (Pines of Carolina)   |   | |
Circuit boards are nothing but self-destruct mechanisms placed in appliances by manufacturers to force users to replace their machines at pre-planned intervals. Manufacturers used to build their stuff to last. These days, they build them to fail. There's no reason a simple thermal circuit breaker could not have been used. They were the industry standard for many years. I wonder how hard it would be to retrofit the machine with one.
Post# 378318 , Reply# 5   9/12/2017 at 20:29 (2,411 days old) by blknblu (CT)   |   | |
I had both Progressive & Intuition canisters before I moved. They are gone now, but her is a schematic from one of them.
Post# 378336 , Reply# 6   9/13/2017 at 05:16 (2,411 days old) by fantomfan57 (Central Texas)   |   | |
Edgar, I often wondered about the C-boards...you may be right! Sven, thanks for sharing. Not be trained, I will have to study this and the other you posted to the other vintage section. |
Post# 378501 , Reply# 9   9/16/2017 at 08:45 (2,407 days old) by fantomfan57 (Central Texas)   |   | |
not doubting your post, but I will ask him about that very thing. During our conversation the subject of Volts and Amp.s surfaced. Very good point, I will post his reply. |
Post# 378538 , Reply# 11   9/17/2017 at 00:40 (2,407 days old) by tolivac (Greenville,NC)   |   | |
The fuse in the vacuum-15A 125V.A 12V one here may not be safe.Stick to the PROPER replacement.Current causes the fuse to blow-but if the volt rating of the fuse is too low-it can arc over. |
