Thread Number: 34857
kirby legend 2 headlight problem |
Post# 376184 , Reply# 1   7/31/2017 at 12:24 (2,454 days old) by sptyks (Skowhegan, Maine)   |   | |
Nedludd:
The Legend II uses a 120/240 volt headlight bulb.
If the floor nozzle or hose is not attached to the powerplant, the Headlight will not turn on when you push the power switch. Instead the small red Power Light located on top of the powerplant just behind the headlight housing will illuminate in Red.
The safety switch prevents the motor from turning on if the nozzle or hose is not attached to the powerplant. The safety switch also determines weather the motor runs on high speed or low speed. When the floor nozzle is attached, the motor runs in Low Speed (approx. 12,000 RPM). When the Hose is attached the motor runs in High Speed (approx. 16,000 RPM).
