Thread Number: 34734
Electrolux 7000 C153A Vacuum Cleaner Problem |
Post# 375127 , Reply# 1   7/10/2017 at 17:35 (2,479 days old) by blackheart (North Dakota)   |   | |
From what i've seen the most common cause of the machine being too sensitive is this valve. The valve controls the sensitivity of the auto shutdown. I have also seen the mechanism at the front of the machine near the switch be the problem before.
If all else fails you could just disconnect the valve assembly the only disadvantage to that is it will no longer shut down on it's own when the bag becomes filled. CLICK HERE TO GO TO blackheart's LINK |
Post# 375128 , Reply# 2   7/10/2017 at 17:49 (2,479 days old) by allen (Richlands)   |   | |
Thanks. At least for now, I think I'll disconnect it. Do I disconnect one or more hoses or do I do it somehow with the wires? Allen |
Post# 375136 , Reply# 3   7/10/2017 at 21:56 (2,479 days old) by Luxkid1980 (Richmond, Virginia)   |   | |
You can just connect one of the hoses that go to the control valve. That will over ride the full bag auto shut off. |
Post# 375190 , Reply# 6   7/11/2017 at 21:59 (2,478 days old) by Luxkid1980 (Richmond, Virginia)   |   | |
This YouTube video shows which vacuum hose to disconnect. |
Post# 375225 , Reply# 7   7/12/2017 at 11:22 (2,477 days old) by lux14 (Leawood Kansas)   |   | |
Thanks Lux Kid 1980!!!! Really appreciate you taking the time to post the UTube direction! One more question, you just disconnect the top line and peave it free correct? Thanks again!!!! |
Post# 375229 , Reply# 8   7/12/2017 at 13:49 (2,477 days old) by luxkid1980 (Richmond, Virginia)   |   | |
no problem! Yeah,I followed that same video with my vacuum and just left the tube there disconnected. Was an easy fix. I just check regularly to make sure the vacuum bag is not full. |
Post# 375233 , Reply# 9   7/12/2017 at 15:00 (2,477 days old) by dysonman1 (the county)   |   | |
OR, you could just fix it. The hose that connects at the intake tube (the part that goes INTO the bag), connects to a plastic piece molded to the side of that tube. The hole is clogged with dust (happens all the time). A simple cleaning with a wire from a bread twisty tie will solve the problem with the machine shutting off when a hand is placed over the intake.
The machine isn't supposed to shut off when a hand is placed over the hose end. To that end, the tube from the front door communicates at the valve with a tube that connects to the bag chamber itself. These two equalize the pressure at the valve when a hand is placed over the hose end. When one is clogged, it throws it all off balance. Don't just disconnect the tubes, actually fix the problem. It's not that difficult. I've done this hundreds of times over the years for customer's repair job machines. And charged good money to do this simple repair. |
