Thread Number: 34592
I never seen this Tristar before |
Post# 373889   6/14/2017 at 20:03 (2,506 days old) by kirbykid63 (Wilmington Delaware)   |   | |
http://www.ebay.com/itm/TriStar-IEC-EX30... |
Post# 373891 , Reply# 1   6/14/2017 at 20:36 (2,506 days old) by kenkart ()   |   | |
That's DIFFERENT!! |
Post# 373897 , Reply# 2   6/14/2017 at 21:09 (2,506 days old) by Ctvacman (CT)   |   | |
It has the 50th sticker which makes me scratch my head that much more |
Post# 373902 , Reply# 3   6/14/2017 at 22:26 (2,506 days old) by suckolux (Yuba City, CA)   |   | |
Post# 373911 , Reply# 4   6/14/2017 at 23:37 (2,506 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
I have a theory on how this TriStar EX30 came to be in existence.
We all know that Harold Schoettler left Interstate Engineering, because Interstate was planning to steal his design for the next TriStar & terminate his employment. In 1989 he founded his company Schoettler Research & Engineering Corporation in Huntington Beach, California, & built the Patriot & Airstorm canisters. I am thinking, since Schoettler left the company & took the designs with him, this was Interstate's answer to Schoettler's copycats, & their answer to what the next generation TriStar would be. TriStar here in Canada was still selling machines in 1993, the year this vacuum was made, with the 50th anniversary sticker, so it makes sense this model has one too. Chances are, this was a experimental model in a limited market to test it out with the public to see if they would like it or not. And in this case, it failed. Hence why it is so uncommon & rarely seen. The only thing I find suspicious with this model is the serial number tag on the front....it isn't the same as Interstate Engineering made them before, plus they are usually date coded, the first two digits usually tell the year it was made, something not done with the serial number on this TriStar. That in itself is odd & suspicious. I kind of like the design, though. It looks like some designer decided to put a modern spin on 1950's design, especially the filter grille at the back. And, since the EX30 has the newer style TriStar powerhead, we now know what year for sure the newer style was introduced. The only things I don't like are is it seems there would be no way to wrap the cord & still have the hose connected, & the filter grille in the back would eliminate the TriStar Filter Fresh system, & of course we have no idea if there would have been any optional exhaust filters for this EX30. It would have also been nice to have seen the hose handle upgraded with a suction release valve & on/off powerhead switch. Rob |
Post# 373979 , Reply# 6   6/15/2017 at 17:57 (2,505 days old) by Dysonman1 (the county)   |   | |
4
Post# 373984 , Reply# 7   6/15/2017 at 19:34 (2,505 days old) by Reo580 (Holland, Michigan)   |   | |
Post# 374036 , Reply# 8   6/16/2017 at 15:35 (2,504 days old) by dysonman1 (the county)   |   | |
6
Post# 374044 , Reply# 9   6/16/2017 at 17:14 (2,504 days old) by sleepdoc (St. Louis, MO)   |   | |
4
Post# 374058 , Reply# 10   6/16/2017 at 21:33 (2,504 days old) by FantomFan (Rochester, New York)   |   | |
Post# 374161 , Reply# 11   6/19/2017 at 14:11 (2,501 days old) by compactc9guy (Bathurst NB)   |   | |
to me its a kit
top part of a patriot put o nth e base of the Tristar CXL EX 20 whit the 50 anniversary edition sticker put ion it it screams tristar on the base but patriot on the top sandwich if you ask me .... some one took two machine and made one part of a Patriot and part of a Tristar CXL EX 20 thats my guess even the attachment kits scream TRISAR CXL from the power head hose ect tristar plus top of patriot equal tristar ex 30 the ex is only used on the CXL EX 20 after all i wonder |
Post# 374180 , Reply# 12   6/19/2017 at 19:50 (2,501 days old) by Dysonman1 (the county)   |   | |
Here's what, to me, is so interesting about it. First of all, interstate engineering had to tool up to make it. Those are diecast metal parts. There was tremendous cost involved. Since it has the 50th anniversary sticker, it had to be designed well before the 50th anniversary. Another interesting thing is the power nozzle. That is the very last series of power nozzle, yet, the 50th anniversary of interstate engineering was 1997. We know that Electrolux bought interstate engineering in, I believe, 1999. Or 2000. Once I get the machine, the date stamp on the lam motor will reveal The approximate date that this machine was manufactured. I have never seen one before, nor have I ever seen anything at all in printing about it. This was not cobbled together, but actually manufactured by interstate engineering in California.
Post# 374187 , Reply# 13   6/19/2017 at 23:33 (2,501 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
You have made some good points there. But, I think this must have been designed sometime between 1990 to 1992.
If you look at the back of the cleaner, at the end of the metal strip that houses the pn receptacle, there is a sticker that indicates a 93 on it. To me, this makes perfect sense....we all know Harold Schoettler left Interstate in 1989, so my guess is when he left & took the design, they had to start from scratch & scrambled to get a new design ready for market. Hence why the 50th Anniversary sticker stuck around for so long on the CXL model. It doesn't make sense to me this would have been designed sometime in the mid 1980's....why would they have another engineer come up with this design at the same time Harold Schoettler was with the company & designing what was supposed to be the new TriStar? It just doesn't make sense, in my mind, that a company would hire 2 designers with 2 designs for 1 product. I highly doubt higher levels of management would have known or be able to predict his departure from the company. As for the PN being the last design, it could have been that it was just slowly being introduced to distributors in 1993, or, like the EX 30 itself, it was a experimental powerhead, & it just so happens this was one part of the design was kept & the rest scrapped. Either way, I am glad that you were able to get the vacuum & preserve & take care of it in the museum, Tom. And it will be interesting once you get it & take it apart to see what the motor's manufacturing sticker shows it's date. Rob |
Post# 374323 , Reply# 14   6/23/2017 at 11:35 (2,497 days old) by Dysonman1 (the county)   |   | |
Some pics after receiving the machine. The motor has a 1998 date stamp on it. As does the motor in the power nozzle
Post# 374325 , Reply# 15   6/23/2017 at 12:53 (2,497 days old) by Kirbysthebest (Midwest)   |   | |
Is this a prototype, or do you know if it was ever in production?
I like the styling, maybe they went with the more teardrop style to stay true to the heritage. |
Post# 374354 , Reply# 16   6/24/2017 at 09:25 (2,496 days old) by dysonman1 (the county)   |   | |
Having used it in my home to clean with a few times now, I will say it's much heavier than its counterpart, the CXL. Also, the ability to wrap the cord without taking off the hose, existed already. The downfall of the metal cord clip as well as the plastic 'clip' for cord wrapping on the EX30, is that you can't UNWRAP the cord all at once, without removing the hose.
I wish there was a way to add the 'mushroom hepa filter cap' to this machine, but the exhaust opening is positioned so that nothing will work. Even the old, black, 'microwave popcorn popper' type filter doesn't exit at the correct angle to lock on and work. It's quite possible it's a prototype. I know with Tacony machines, prototypes get put into the field all the time. The huge cost for Tri-Star to tool up to build this would prohibit them from just making a handful for testing. Yet, no one knows how or why it came to exist. |
Post# 404455 , Reply# 18   1/23/2019 at 09:45 (1,918 days old) by rwebb91 (Sullivan Illinois )   |   | |
Post# 404497 , Reply# 19   1/24/2019 at 00:27 (1,918 days old) by ridgidwd0670 (se wood co ohio)   |   | |
Post# 405687 , Reply# 20   2/19/2019 at 16:09 (1,891 days old) by relhall ()   |   | |
Not sure where I grabbed this image but I feel I should post it here. Not mine, though I can dream ~
Post# 405691 , Reply# 21   2/19/2019 at 17:17 (1,891 days old) by broomvac (N/A)   |   | |
Post# 405710 , Reply# 22   2/20/2019 at 00:44 (1,891 days old) by tolivac (Greenville,NC)   |   | |
Demo machine for a shop? |
