Thread Number: 34529
Kirby Avalir- higher speed than prior models? |
Post# 373312   6/6/2017 at 08:15 (2,512 days old) by reo580 (Holland, Michigan)   |   | |
Hi.
I just bought an Avalir for my birthday and I am in love with it. I noticed that it has a smoother transmission than my Diamond and G6 did. it sounds like it runs at a higher RPM rate than any of my prior G models (and Diamond on high speed) did. Anyone else notice this? Does Avalir run at a faster speed than the prior models? My avalir has a rattle when the hose is used that I do not like. I can feel a slight vibration on the motor unit when the hose is on. I rebuilt many, many Kirbys before but never tore into the Sentria-Avalir models. I am going to replace the fan and shaft.The shaft has a very slight wobble to it on the wind-down. I am considering replacing the armature which made me wonder if Sentria II and Avalir had different field coils and armatures than the prior models. Could it be a bent fan shaft? Thanks for any info. , Derek |
Post# 373313 , Reply# 1   6/6/2017 at 08:37 (2,512 days old) by Kirbysthebest (Midwest)   |   | |
Since you just got it, it should still be under warranty. I would seek out a authorized distributor and have the repairs made by them at no cost.
Post# 373338 , Reply# 2   6/6/2017 at 13:32 (2,512 days old) by sptyks (Skowhegan, Maine)   |   | |
Derek,
Believe it or not the Avalir has the exact same motor as the G3 had. The airflow was increased to approx. 137 CFM by redesigning the Mini Emptor on the Sentria II and Avalir. This would most likely be why the Avalir sounds different than older models.
I doubt if the motor is to blame for the vibration. I would have the fan and belt pulley shaft replaced under warranty by your local Kirby dealership. |
Post# 373351 , Reply# 3   6/6/2017 at 15:36 (2,512 days old) by wyaple (Pickerington, OH)   |   | |
I don't exactly when (maybe the Sentria I or Diamond edition), but Kirby definitely increased the motor speed. You can easily hear the pitch difference in my videos of the G6 and Sentria II. I'm aware that the motor part number is the same, but manufacturers make little tweaks all the time...
Here's a pic of an FFT program showing a lower RPM for a G6 versus a Sentria II. BTW, my G4, G5 and G6 all run at the same speed. For those musically inclined, the newer Kirbys sound about one half-step higher than the older G series. Bill |
Post# 373410 , Reply# 4   6/7/2017 at 11:10 (2,511 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 373411 , Reply# 5   6/7/2017 at 11:22 (2,511 days old) by sheetstyler (Mooresville)   |   | |
My avalir I just got it and it sounds like it has more RPM. My doesn't have the problem with the shaft though. I am in love with my avalir it's an amazing machine I got it with the attachments and shampoorer for $80 don't regret it at all
Post# 373415 , Reply# 6   6/7/2017 at 14:11 (2,511 days old) by wyaple (Pickerington, OH)   |   | |
It's interesting to follow Kirby's evolution into higher performance over the years.
There is a 17 CFM difference between my G6 and Sentria II. G6 Nozzle CFM = 120 Sentria II CFM = 137 Here's my partial guess as to how the 17 CFM increase can be accounted for: --9900 RPM / 9300 RPM = 6.45% or about 9 CFM for the increased motor speed (BTW, that's with the brush roll spinning, not just the fan by itself with no nozzle attached.) --Redesigned emptor allowing 8 CFM more airflow (Haven't verified this yet). Total CFM increase = 17 CFM over the older G series machines. I'll take it! Bill |
Post# 373450 , Reply# 7   6/8/2017 at 11:23 (2,510 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 373458 , Reply# 8   6/8/2017 at 12:43 (2,510 days old) by vacuumdevil (Vacuum Hell )   |   | |
Post# 373459 , Reply# 9   6/8/2017 at 13:48 (2,510 days old) by wyaple (Pickerington, OH)   |   | |
dry motor bearings without removing them from the machine.
1) Current meter. Dry bearings will cause additional drag and cause the amperage to increase. I have a post entitled some like "How much power do they use" and you can see my measurements there. 2) FFT (sound) analysis. Since there are boatloads of Kirby videos on YouTube (including from the Kirby company itself), it is very easy to hear the increase in speed in the newer models. I have a Heritage II Legend, G4, G5, G6 and Sentria II so far and I can assure you the bearings aren't dry (yet). Several years ago, when Kirby first released the Sentria II, I immediately heard the speed increase and wondered how much faster it was running. Well, using an FFT program called "Sound Analyzer", I am able to pin it down by placing a recording device (microphone, cellphone, etc.) at the rear of the Kirby in order to get an accurate reading with the brush roll actually spinning (under load). Here's a slightly different screenshot showing more of the program's capabilities with me whistling. It can even pinpoint the frequency and decibel level if you desire. Bill |
Post# 373536 , Reply# 12   6/9/2017 at 14:20 (2,509 days old) by sptyks (Skowhegan, Maine)   |   | |
I spoke to a Friend who has owned a Kirby dealership for many years and he really knows his stuff.
Fact: ALL G series motors from G3 to Avalir not only have the same part number, but they all have the exact same Armature and Field Coil. In other words, no changes have been made to the motor itself.
The changes to RPM and pitch can be mostly attributed to changes in outer bag material and a much cleaner air path due to the design of the newer mini emptor.
I expect that the older emptor design caused some back pressure in the fan chamber slowing the motor down somewhat. The new mini emptor alleviated this problem allowing the motor to reach it's max RPM. This would prove Harley's assumptions to be correct and also account for Bill's increased pitch measurement.
Post# 373548 , Reply# 13   6/9/2017 at 19:21 (2,509 days old) by wyaple (Pickerington, OH)   |   | |
After testing just the Sentira II and G6's outer bag/emptor setup, I continued testing with G5 and G4 assemblies as well. The tests were run with the brush roll spinning and the same (never used) HEPA bag inserted into each assembly. Drum roll please....
Relative to the Sentria's outer bag/emptor setup: Sentria II airflow loss = 0 (default) G6 airflow loss = 8.2 CFM G5 airflow loss = 12.3 CFM G4 airflow loss = 13.3 CFM So this means that the "missing" 8 CFM from my previous estimation has been found. To recap: CFM at the nozzle difference of 17 CFM from a G6 can be accounted for by two changes in the Sentria II/Avalir. 1) 9 CFM increase by the motor running at a higher pitch (faster RPM) and 2) 8 CFM increase by the outer bag/emptor having greater flow through capability. It should be noted that by carefully wrapping the HEPA bag around the filltube so it gently surrounds it from top to bottom (like a hot dog in a bun) paying particular attention to removing creases, I was able to push my Sentria II to a whopping 138.7 nozzle CFM. Below is a picture of today's contestants: |
Post# 373705 , Reply# 14   6/12/2017 at 08:16 (2,506 days old) by Reo580 (Holland, Michigan)   |   | |
You are right: the Avalir takes the same armature as the G-series.
I replaced the armature, front bearing and the fan and shaft ( might as well since I got this far) and now it runs perfect in both carpet and hose mode. I couldn't stand the vibration it had earlier. One of my friends said it sounded like a Kirby. I could hear a viberation / frequency that sounded off to me. I Couldn't live with it. Now I'm happy with it. This thing cleans well and I like its looks too. Many thanks to Kent Oyler @ Kirby Needs for quick, professional service!! I got the parts I needed and they arrived quickly. My Avalir and I thank you. |
