Thread Number: 34299
Central vacs |
Post# 371578   4/30/2017 at 14:55 (2,524 days old) by sebo4me (Cardiff)   |   | |
Post# 371588 , Reply# 1   4/30/2017 at 18:25 (2,524 days old) by vacuuman101 (Vermont )   |   | |
I don't know about MD central vacs but my grandmothers Fasco mastervac II from 1993 was really loud and when it died last summer she got a new Vacuflo FC650 and it is quieter then the old one but it is a little loud. Hope this helps -Jeremy |
Post# 371589 , Reply# 2   4/30/2017 at 19:40 (2,524 days old) by ocscott3085 (DMV)   |   | |
My MD central vacuum is significantly quieter than the Dirt Devil Pro Series it replaced. I actually don't think it would be any louder than a canister vacuum if you were to keep it in a ventilated closet/cabinet. |
Post# 371590 , Reply# 3   4/30/2017 at 19:46 (2,524 days old) by Ctvacman (CT)   |   | |
My vacuflo 566q is incredibly quiet right at the unit. |
Post# 371591 , Reply# 4   4/30/2017 at 20:00 (2,524 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 371592 , Reply# 5   4/30/2017 at 20:17 (2,524 days old) by sebo4me (Cardiff)   |   | |
Post# 371610 , Reply# 7   5/1/2017 at 08:49 (2,523 days old) by sebo4me (Cardiff)   |   | |
Post# 371613 , Reply# 8   5/1/2017 at 10:07 (2,523 days old) by Compactelectra (Palm Springs)   |   | |
In a hall closet in my home in LA. No basement and a detached garage. I originally had a regular MD unit but my partner worked from home and the unit was next to his office. Way too loud for him when the housekeeper was there twice a week. Replaced it with a Silentmaster and problem solved. Those Silentmaster units are perfect for closet installations. Very quiet.
Post# 371617 , Reply# 9   5/1/2017 at 10:45 (2,523 days old) by sebo4me (Cardiff)   |   | |
Post# 371624 , Reply# 11   5/1/2017 at 12:54 (2,523 days old) by sebo4me (Cardiff)   |   | |
Post# 371632 , Reply# 12   5/1/2017 at 15:01 (2,523 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 371638 , Reply# 14   5/1/2017 at 19:43 (2,523 days old) by panasonicvac (Northern Utah)   |   | |
It depends on which kind you would get because some are noisier than others and some are quieter than others. We sell Simplicity and MD central vacuums because not only they are ridiculously powerful but they are also extremely quiet. If you're going to get an MD, go for the Silentmaster lineup because they're quieter than the other MD models such as the Flo-Master, Air Force, Modern Day, and Air Master.
Post# 371639 , Reply# 15   5/1/2017 at 19:59 (2,523 days old) by Oreck_XL (Brooklyn, New York 11211)   |   | |
Post# 371661 , Reply# 16   5/2/2017 at 08:48 (2,522 days old) by vacerator (Macomb Michigan)   |   | |
air moving through the pipes with daily use dries them out. |
Post# 371723 , Reply# 17   5/3/2017 at 03:22 (2,521 days old) by myles_v (Fredericksburg, VA)   |   | |
If you do bury the pipes, be sure to go deep enough that it's below the frost line and put the pipe and wire inside of a larger pipe. This is supposed to prevent the central vac tubing from being crushed, cracked, or causing condensation.
I have a Honeywell central vac/made by Electrolux Home Care Products/same company that owns Beam. It's not unbearably loud being in the same room as it, but it is vented outside. Being near the exhaust while it's running is almost unbearable. Our exhaust vent is on the back of our house and you can ver clearly hear it from the front of the house. You can't hear it much inside though. |
Post# 371727 , Reply# 18   5/3/2017 at 06:24 (2,521 days old) by tolivac (Greenville,NC)   |   | |
Air drying the pipes out-if there is WATER in the pipes from condensation or leaking the water CAN get into the units motor--NOT good!Better to have the central machine in the building where it will be used. |
Post# 371766 , Reply# 20   5/4/2017 at 06:06 (2,520 days old) by sebo4me (Cardiff)   |   | |
Post# 371777 , Reply# 21   5/4/2017 at 15:18 (2,520 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
It's about 900 square feet I think. I have one in each bedroom, two in the living room, two in the dining room, and one in the kitchen. Mike |
Post# 371837 , Reply# 24   5/6/2017 at 10:42 (2,518 days old) by sebo4me (Cardiff)   |   | |
