Thread Number: 34287
Cleaning Kirby Shake out Bags |
Post# 371446 , Reply# 1   4/26/2017 at 23:47 (2,553 days old) by jimjimmunster (Hammond, Ind.)   |   | |
Post# 371523 , Reply# 2   4/28/2017 at 17:21 (2,551 days old) by vacuser (milford,ohio)   |   | |
vacuum it out & leave it alone. do not clean the pores of the bag out by washing it.
Post# 371525 , Reply# 3   4/28/2017 at 17:30 (2,551 days old) by CharlesKirby66 (Manteca, CA)   |   | |
Once I remove them from the Emptor, I turn them inside out and use a Kirby Zippbrush to get the embedded dust, dirt, and detritus from the bag. I then use the crevice tool to get the dirt in the seams' crevices.
Next, for a bag that was not too dirty, I will use a Kirby as a portable shampooer to shampoo the inside of the bag with Kirby Carpet Shampoo. Depending on the soil level, you can use a clean white cloth or clean, relatively soft-bristle brush to work the suds into the bag. I then let it hang dry and once dry, I use a Zippbrush again to remove the trapped dirt and dried suds from the bag. Comes out bright and smells great!
If the bag is really dirty or splotchy, or if it's a refurbishment, I will use warm water in a bucket with Woolite. I hand agitate and gently scrub the bag against itself to remove built up gunk. I dump the dirty water and refill with warm water, and hand agitate and scrub again to rinse the detergent out. I then let it air dry.
I hope this helps! |
