Thread Number: 34182
Miele C3 Airflow Losses: Some Meausred & Some Estimated |
Post# 370433   4/10/2017 at 15:44 (2,564 days old) by wyaple (Pickerington, OH)   |   | |
First off, thanks to Devin for providing the two actual measured readings. He works in a store that actually sells Miele products.
By The Numbers: 141 Motor CFM: This is provided by the manufacturer and reflects the maximum motor airflow when not installed into the machine body. 111 CFM at the canister base: After installing the motor into the canister base with all bags and filters, this is my estimation of the remaining airflow. 101 CFM at the hose end: This is the measurement taken with the hose stretched out as straight as possible. 95 CFM at the wand end: This is the measurement taken with the hose stretched out and the wands opened up to approximately three feet. 85-89 CFM at the nozzle end: This is my estimate of the airflow after passing through the final connections and u-joint at a 45 degree angle. Total (estimated) airflow losses from the canister base to the power nozzle (held at a 45 degree angle to the floor) is 111-87(averaged between 85 and 89) = 24 CFM or about 22% of the original airflow. Of course as the bag fills, the airflow will drop in addition to more losses depending on how the hose is coiled. Comments welcome of course. Bill |
Post# 370442 , Reply# 2   4/10/2017 at 18:26 (2,564 days old) by wyaple (Pickerington, OH)   |   | |
Post# 370475 , Reply# 3   4/11/2017 at 10:31 (2,563 days old) by wyaple (Pickerington, OH)   |   | |
Cloth HEPA Bag Losses (Same dirt type in all three bags of course)
Hoover Tempo Widepath (Crucial HEPA Bag) 0% full = 114 CFM (Body) and 106 CFM (Hose) 50% full = 97 CFM (Body) and 90 CFM (Hose) 100% full = 99 CFM (Body) and 91 CFM (Hose) <-No, those numbers are not a mistake, dirt can shift in the bag slightly affecting results by a percent or two. Electrolux Olympia One (Perfect HEPA Bag, new vinyl hose) 0% full = 102 CFM (Body) and 85 CFM Hose 50% full = 85 CFM (Body) and I don’t have the hose measurement handy 100% full = 87 CFM (Body) and 79 CFM Hose Kirby Heritage II Legend (Kirby HEPA Bag, new Amodel fan installed) 0% full = 161 CFM (Body) and 105 CFM (Hose) 75% full = 141 CFM (Body) and 105 CFM (Hose) 100% full = Didn’t perform formal measurements but quick check yielded no appreciable additional losses. It’s the reader’s choice if this would be believable or not. Full Bag (Kirby 75%) Body RESULTS: #1 with probably a few CFM less than this is the Kirby at <141 CFM #2 with 99 CFM is the Hoover Tempo #3 with 87 CFM is the Electrolux Full Bag (Kirby 75%) Hose RESULTS: #1 with probably a few CFM less than this is the Kirby at <105 CFM #2 with 91 CFM is the Hoover Tempo #3 with 79 CFM is the Electrolux |
Post# 370476 , Reply# 4   4/11/2017 at 10:33 (2,563 days old) by wyaple (Pickerington, OH)   |   | |
Percent lost from empty to full (75% Kirby) HEPA bag:
Electrolux (Body) = 14.7%, Electrolux (Hose) = 7.1% Tempo (Body) = 13.2%, Tempo (Hose) = 14.2% Heritage II (Body) > 12.4%, Heritage II (Hose) = 0% <- Yes, I know that’s weird but apparently Kirby’s high speed hose mode make up the difference somehow. Bill |
