Thread Number: 34029
Opinions On The Perfect Power Team |
Post# 368877   3/21/2017 at 20:55 (2,585 days old) by crazykirbydude (Lexington, KY)   |   | |
It looks exactly the same as an 80's Electrolux. Does anyone here own one? I wonder what it sounds like and how well it cleans.
Post# 368946 , Reply# 3   3/22/2017 at 20:11 (2,584 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
Both vacuums that I mentioned are quite powerful. I have never tried an Aerus bag in them because the Perfect bags are cloth instead of paper and filter much better, so even if you could use an Aerus bag in them, there would be no reason to. |
Post# 368953 , Reply# 4   3/22/2017 at 22:18 (2,583 days old) by Tseg (World Traveller)   |   | |
According to user reviews of a large online vendor selling the Perfect brand they sometimes have spotty durability and vendor support is questionable. I suppose if one rolls the dice it can be a great acquisition. |
Post# 368966 , Reply# 5   3/23/2017 at 00:20 (2,583 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Unfortunately, I agree with the user reviews saying the durability of the product is spotty & manufacturer support is questionable. Having said that, reality is most people will be taking it to a repair shop if it breaks, regardless if bought online or thru a vac shop, & they will be the ones to source parts & deal with the manufacturer on warranty issues.
As for the quality of the product, they have had their issues, but it seems they have sorted those out. The cordreel was a fault & was redesigned. Another issue was the mounts inside the powerhead that attach the motor & components was poor quality & needed a redesign & better materials used. In addition, compared to the Electrolux motors originally used in the Electrolux canisters this copies, the Ametek Advantek motor used in the Perfect C101 is considered a "disposable" motor, the carbon brushes are under the field coils, not on top, & there is no way to change them & service the motor. My thinking is that the RPM's the motor spins at are so fast to create the 125" waterlift it produces, that it wears the entire motor out so it cannot be repaired, just thrown away if it breaks down. The main issue the Perfect canisters still have is the hose, like n0oxy said above the suction relief valve wearing out & not staying closed eventually is a issue, plus these aftermarket Electrolux hoses tend to have the PN receptacle that supplies power to the wand wear out prematurely & require replacement. However, if one wanted to, you could buy a genuine Aerus Electrolux hose to use on the Perfect & it would work fine with no issues. I have recommended, & still do recommend the Perfect canister for those that want something simple, with no electronics, & LOTS of power, that cleans effectively. Having said that, for those that are able to take things apart & do repairs, I do first recommend buying a older Electrolux metal canister, such as the Marquise & Grand Marquise, & refurbishing it. There is a genuine Aerus Electrolux motor, made by the former motor manufacturer Electro Motor, that pulls 117" waterlift, so same power as the Perfect C101. Plus the powerheads are easy to rebuild, the metal Electrolux canisters are dead simple to work on & hardly break down, & the one distinct advantage Aerus Electrolux has is they have the Automatic Control bag change feature, that allows you to customize & set when you want the cleaner to alert you a bag change is required. Perfect canister vacuums DO NOT have that feature, & it is one feature that really is beneficial to have on this design, since the Type C bags, whether paper 4 ply or HEPA Cloth, are known to clog a little quicker than other models. If you rebuild a Electrolux, it is a cleaner that will be great value, do a terrific job cleaning, & last a long time for it's owner. Rob |
Post# 369359 , Reply# 7   3/27/2017 at 20:34 (2,579 days old) by panasonicvac (Northern Utah)   |   | |
