Thread Number: 34020
Power Nozzle Dyson Canisters |
Post# 368790   3/20/2017 at 14:04 (2,587 days old) by vacmaster (San Diego)   |   | |
Seems they exist in Japan. Shame they can't be made elsewhere as they would clean much better than the normal turbo nozzles, which are a sad excuse for a cleaner head.
(When you open the link a tab will pop up in the top right corner, click translate) CLICK HERE TO GO TO vacmaster's LINK |
Post# 368802 , Reply# 2   3/20/2017 at 16:02 (2,587 days old) by crazykirbydude (Lexington, KY)   |   | |
I know of a variant of the Dyson DC05, called the DC05 Motorhead. The motor brush was used for the Zorb powder. The brush had three settings. The first was brush with no suction, (for grinding in the powder) setting two is brush with suction and setting three is suction only.
CLICK HERE TO GO TO crazykirbydude's LINK |
Post# 368817 , Reply# 3   3/20/2017 at 18:09 (2,587 days old) by vacmaster (San Diego)   |   | |
Post# 368825 , Reply# 5   3/21/2017 at 00:59 (2,587 days old) by cuffs054 (monticello, ga)   |   | |
Could you use the Zorb with a Kirby rug shampooer brush (dry)? Then vacuum as usual? |
Post# 368831 , Reply# 6   3/21/2017 at 02:26 (2,587 days old) by tolivac (Greenville,NC)   |   | |
Interesting experiment--maybe someone out there who has a Dyson canister or upright-could try a Volt powernozzle with the Dyson.To me the Volt powernozzle beats them all!Have Sebo,Lindhaus-like the Volt much better. |
Post# 368847 , Reply# 8   3/21/2017 at 12:33 (2,586 days old) by dysonman1 (the county)   |   | |
The only Dyson canisters that used standard 1 1/4 inch hose ends, were the DC02 and DC05. Both UK models (I have some very rare ones in the collection, such as the ReCyclone and the Antarctica Solo).
I have hooked them up to a Volt power nozzle. Since those models use 240 volts, the suction is outstanding - similar to many high powered central vacs. The Volt makes the Dyson a "tandem-air" cleaner and it works splendidly. In the 120 volt machines, the DC21, DC22, and DC23 models had electric power nozzles. The DC22 is very rare, with its digital motor (I love mine), the DC21 and DC23 Motorhead models were much better selling machines. They do not use standard size wands nor openings, and cannot (to my knowledge) be hooked up to any other machine. |
Post# 368855 , Reply# 9   3/21/2017 at 14:33 (2,586 days old) by Mike811 (Finland)   |   | |
Here is one adaptor for Dyson. However they don't mention is it 32mm or 35mm. Most likely 32mm
CLICK HERE TO GO TO Mike811's LINK on eBay
Post# 368856 , Reply# 10   3/21/2017 at 14:40 (2,586 days old) by Mike811 (Finland)   |   | |
Post# 368893 , Reply# 12   3/22/2017 at 00:30 (2,586 days old) by henrydreyfuss (Ohio)   |   | |
In the US, there have been two canister models with powered nozzles: the DC21 and DC23 Motorhead. They remain the best cleaning Dyson canisters ever sold in the US for carpet cleaning.
I own a new model Dyson canister (the non-Cinetic model, which has a pre-motor filter), and while I like the canister unit itself, I was quickly fed up with the stock hose, wand, and turbine nozzle. I made an adapter that converts the latest Dyson tool connection, to work with most generic setups. This has greatly added to both the versatility and usability of the vacuum. My preferred setup is to add Tacony's awesome 12' hose, and use a Turbocat nozzle, offering great cleaning coverage. The Dyson has plenty of suction to do a good job cleaning with this setup, plus it's a pleasure to not have to pull the weight of the vac around, every time you take a step. |
Post# 368900 , Reply# 13   3/22/2017 at 02:27 (2,586 days old) by tolivac (Greenville,NC)   |   | |
220-240V vacuums--What amperage does the 220V Dyson take?For a rough equivelant-a 5A 240V motor would be about equal to a 10A 120V one. |
Post# 368908 , Reply# 14   3/22/2017 at 10:25 (2,585 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
How did you make an adapter to use standard attachments? It drives me nuts when manufacturers use nonstandard hose sizes, especially when there is no good reason to do so, certainly no benefit to the consumer, perhaps it benefits the manufacturer because you are limited to using only their attachments. |
Post# 368927 , Reply# 15   3/22/2017 at 16:29 (2,585 days old) by Mike811 (Finland)   |   | |
I have done several powerteams from the straight suction canisters. Reason is simply that powerteam canisters are VERY rare in the Finland and selection in the eBay UK or Germany (same voltage) is slim also. Importing from the US is extremely costly and voltage is different.
This seen in the pictures was especially important for me because this Philips Performer Pro is extremely powerful. It pulls 9 from the baird air flow meter and suction is 500 airwatts. Now it has Wessel Werk 340 from the HYLA vacuum. Whole explanation in the link. CLICK HERE TO GO TO Mike811's LINK |
Post# 368928 , Reply# 16   3/22/2017 at 17:08 (2,585 days old) by gsheen (Cape Town South Africa)   |   | |
Post# 368937 , Reply# 17   3/22/2017 at 18:50 (2,585 days old) by Mike811 (Finland)   |   | |
I don't see any benefit of 220 volts compared to the 110 volts.
One example from my Philips. 2200 watts = 20 amps with 110v and 10 amps with 220v. Now EU has stopped this madness and now most of our vacuums only use around 700w-900w (900w is max allowed) That is 6-8 amps (110v). Unfortunately we don't get anymore those suction monsters Like my Philips with 500 airwatts. However when the motor speed is set to the middle it still pulls 5 on the airflow meter. So for the US people 12 amps is kind of sweet spot. |
Post# 368938 , Reply# 18   3/22/2017 at 19:14 (2,585 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 368954 , Reply# 20   3/22/2017 at 22:18 (2,585 days old) by Mike811 (Finland)   |   | |
Just some notes about very high powered vacuums. My example was what you get when certain vacuum take the full advantage of the high powered motor.
Problem was that many of the manufacturers used bad quality motors and they just wasted the electricity. One problem is that when the new EU law came manufacturers just put very low powered motors to vacuums that are designed to be used with higher powered motors. Result: poor performance. I can't deny that having extremely powerful vacuum has its advantages. You don't have to "hunt" the dirt. Nozzle picks up more far away from the corners and so on. It makes cleaning faster and easier. Some numbers: High powered vacuums had around 300-500 airwatts. Now with low powered vacuums it's 150-250 airwatts. But for some reason many old twin fan vacuums has a great suction/airflow. For example my Lux Royal with 1150w (10amp) motor pulls over 7 on the baird airflow meter and suction is equally impressive. So in this case no need for insane motor wattage. I don't see myself buying these new limited power vacuums. Instead I will get old good quality vacuum. And let's not forget that all important powerhead. |
Post# 369124 , Reply# 21   3/25/2017 at 00:53 (2,583 days old) by tolivac (Greenville,NC)   |   | |
The 5-7A 240V motors would be equivelant to 10A and 14A at 120V No advantage for the 240V motor in this case. CLICK HERE TO GO TO tolivac's LINK |
Post# 369866 , Reply# 22   4/3/2017 at 03:26 (2,574 days old) by henrydreyfuss (Ohio)   |   | |
Post# 369876 , Reply# 23   4/3/2017 at 08:47 (2,574 days old) by kirbyvertibles (Independence, KS)   |   | |
