Thread Number: 34006
Bagless vacuum with a good airflow. Is there any? |
Post# 368686   3/19/2017 at 12:22 (2,592 days old) by Mike811 (Finland)   |   | |
So after I got my baird airflow meter and testing different vacuums bagless/bagged. I discovered something interesting.
Bagless vacuums seems to have a poor airflow compared to bagged ones. Some examples: Bagged vacuums (clean air type) pulled around 5 to 9. Best: Philips Performer Pro (20amps 2200w) pulled 9. Bagless vacuums pulled around 2 to 4,5. Best: Electrolux UltraFlex (19amps 2100W) This is something what I have seen in numerous Youtube videos also. Also the best bagless vacuum Dyson usually have only 2 from the baird airflow meter. So question is: Is there really bagless vacuum that can pull at least 5 to 6?? Thanks |
Post# 368692 , Reply# 1   3/19/2017 at 12:51 (2,592 days old) by sebo4me (Cardiff)   |   | |
Post# 368693 , Reply# 2   3/19/2017 at 12:56 (2,592 days old) by sebo4me (Cardiff)   |   | |
Post# 368694 , Reply# 3   3/19/2017 at 13:04 (2,592 days old) by Mike811 (Finland)   |   | |
Nice to hear that.
I have Shark Rotator Lift-Away Pro which cleans quite well (not good as the Kirby G6). I just have one carpet where it struggles to get it clean. Otherwise pretty good and it only pulls 2 on the airflow meter. Kirby pulls 10. Shark is just very easy and versatile to use.
Post# 368699 , Reply# 4   3/19/2017 at 13:31 (2,592 days old) by sebo4me (Cardiff)   |   | |
Post# 368703 , Reply# 5   3/19/2017 at 13:51 (2,592 days old) by Mike811 (Finland)   |   | |
Post# 368704 , Reply# 6   3/19/2017 at 13:59 (2,592 days old) by sebo4me (Cardiff)   |   | |
Post# 368728 , Reply# 7   3/19/2017 at 20:08 (2,592 days old) by wyaple (Pickerington, OH)   |   | |
Mikko,
You can see that from the base of the machine (BEFORE the cyclones) in the various bag less vacuums listed here, airflow is excellent. Baird tests reveal a 9-10 range. AFTER the cyclones, the airflow drops like a stone, typically down to a 3. The best airflow at the hose end I have is a DC14, which scores a 4 (about 77 CFM). BTW, when testing your machines, be sure to stretch the hose out straight and as level as possible. Twisting the hose up like a pretzel reduces airflow and thus your Baird reading will be lower. Bill |
Post# 368729 , Reply# 8   3/19/2017 at 20:21 (2,592 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 368738 , Reply# 9   3/20/2017 at 00:41 (2,591 days old) by sebo4me (Cardiff)   |   | |
Post# 368748 , Reply# 10   3/20/2017 at 06:26 (2,591 days old) by sebo4me (Cardiff)   |   | |
Both a direct air and clean air vac work on the same principle.
The motor spins a fan which causes a drop in ambient pressure and causes air to flow. A direct air cleaner has the bag after the fan and pushes the dirt into the bag. A clean air machine has the bag before the fan and pulls the dirt into the bag. It's not rocket science is it 😁 Interesting results. So it's the cyclones that reduces the airflow. |
