Thread Number: 33816  /  Tag: 80s/90s Vacuum Cleaners
How rare is this Heritage?
Post# 367246   2/20/2017 at 20:14 (2,614 days old) by genemegamat (Colorado)
I recently picked up this Heritage and have never seen one with the small power nozzle on it. Is it rare? What's interesting is that the casting on the nozzle appears to work on the Heritage and 516 to Sanitronic safety switches. Thanks for your help!
Post# 367248 , Reply# 1   2/20/2017 at 20:25 (2,614 days old) by KirbyCollector (Columbus Ohio USA)
kirbycollector's profile picture
The Kirby itself is a common Heritage II, it's the nozzle that's rare. It's an optional 13 inch nozzle that Kirby had for the Heritage/Legend models. They're pretty rare. That's a great find.
Post# 367260 , Reply# 2   2/20/2017 at 23:39 (2,614 days old) by genemegamat (Colorado)
Heritage 2 power head
This Heritage had that nozzle on it and on his shelf he had two other nozzles with the exact same markings. One was shaped like an Omega/Classic/Tradition and another was just a plain old Heritage 2 nozzle...I'm guessing they were all just options? The other two nozzles didn't have the muliple safety switch positions, so I didn't grab them. Should I have?
Gene
Post# 367263 , Reply# 3   2/21/2017 at 06:00 (2,614 days old) by KirbyCollector (Columbus Ohio USA)
You could get the other three nozzles. Or depending on the serial number, you could get an original nozzle for this machine.
The Heritage IIs made in 1984 had the big classic style nozzle,
The ones made in 1985 had the newer style nozzle without an indicator light.
The indicator was added in 1986
Post# 367275 , Reply# 4   2/21/2017 at 09:56 (2,614 days old) by kirbyvertibles (Independence, KS)
The bigger classic style one I'd say is the most uncommon
Post# 367281 , Reply# 5   2/21/2017 at 10:46 (2,614 days old) by kenkart ()
That small head
Was optional,most often ordered by Churches because it would fit between pews better than the oversized monstrosity used since the Classic, With the small head the power is concentrated and these clean rings around the wider ones...A great find.Much more convienent in the average home.
Post# 367284 , Reply# 6   2/21/2017 at 11:24 (2,614 days old) by KirbyClassicIII (Milwaukie, Oregon)
genemegamat
Gene,
Like Thom (KirbyCollector) and Hans (kenkart) said, the 13" wide nozzle was indeed an option and was preferred by those end users and businesses that have many tight spots. Going by the 3rd picture, it appears your 13" nozzle, as well as the machine itself, must be made after December 1984 (x8412xxxxx) because the attaching lug for the Classic Omega/III/Tradition speed switch is not present.
And also like Thom points out, the other nozzles you're referring to were used depending on the serial number of the machine itself. If the HII in question was made between September and December 1984 (s/n x8409xxxxx to x8412xxxxx), the nozzle casting would not only have wings but also the attaching lugs for the Classic Omega/III/Tradition speed switch (134374/134380); if built between December 1984 and March 1985 (s/n x8412xxxxx to x8503xxxxx) then that lug on the back of the nozzle casting for the older machines' speed switch was removed.
Here's my small HII nozzle (this one was made in September 1985)... mine too lacks the Classic Omega speed switch attaching lug.
