Thread Number: 33402
hoover junior 1334 bearings |
Post# 364454 , Reply# 1   12/31/2016 at 02:03 (2,645 days old) by chicagomike (Plover, WI)   |   | |
if you have those small bearings removed from the steel rod and removed from inside the metal housing/end caps they are recessed into, you do not need to take apart the bearing any further to grease them... There is so much slop/opening/play in the bearing you can regrease them no problem. Clean them well before re-greasing as the ball bearings should spin very freely before adding grease back to them.
