Thread Number: 33324
HENRY HOOVER REDUCED POWER |
Post# 363693 , Reply# 1   12/16/2016 at 06:35 (2,680 days old) by Turbo500 (West Yorkshire, UK)   |   | |
The new Henry's perform better than the old 1200w models, especially with the new floortool - see video link below.
Whilst the motor power has been reduced, Numatic have redesigned the motor to generate equally as much airflow. The performance of a vacuum should never be measured against motor wattage alone. The wattage is simply telling you how much electricity it's using. Airflow is the key indicator and there are numerous ways to generate high airflow with low power. With cylinder vacuums, I've often found that the floortool can make all the difference also. You can have all the suction power you want, but with a crap floortool it simply won't lift the dirt off the carpet. CLICK HERE TO GO TO Turbo500's LINK |
