Thread Number: 33238
Help with an Electrolux Model E |
Post# 362811 , Reply# 1   11/26/2016 at 19:17 (2,706 days old) by bikerray (Middle Earth)   |   | |
I'm guessing that the rubber gasket you are talking about is the diaphragm that goes from around the motor to the support frame of the motor. The diaphragm should go up against the bulkhead between the bulkhead and the support frame. The screws or studs will go thru the gasket and the support ring into the bulkhead.
It sounds like you inverted the diaphragm and put it inside the bag chamber housing. You shouldn't have to remove the bag chamber as this is all done from the motor end. |
