Thread Number: 33144
CDN Electrolux 88 Help! |
Post# 362005 , Reply# 1   11/4/2016 at 22:25 (2,727 days old) by compactc9guy (Bathurst NB)   |   | |
The hose can be bought on ebay , the door has screws at the top and bottom aof the machine play whit those once you open the door you will see the screws also the spring could be the issue i have a model zb86 that i need a motor and motor plate for it so those are great machine once they get the repairs done
Post# 362023 , Reply# 2   11/5/2016 at 12:11 (2,727 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Very nice Electrolux ZB88 you found there! Looks like it's former owner took good care of it.
First of all, as for a replacement hose, there is no aftermarket, generic or genuine replacement hoses being made presently for the Electrolux 80-series canisters. You will have to call a few Aerus dealers across Canada & ask around if they have any spare hoses they can sell. And be sure to specify you ONLY want a vinyl hose, if you get another cloth hose it will only be a matter of time before it leaks like your present hose. Your next option would be to take the hose to a local vac shop, have them gut the hose material from both ends, & use rubber cuffs & new vinyl hose material to make you a new hose. As for the bag cover not closing completely, that gap you are experiencing is normal & nothing to worry about. Every 86, 88 or 89 I have ever owned has been like this. And you also say you have strong suction, so you should have no problems once you get yourself a new hose. Rob |
