Thread Number: 3312
Help with with the right Kirby attachment... |
Post# 37183 , Reply# 4   4/4/2008 at 17:37 (5,864 days old) by vinvac (Dubuque IA)   |   | |
Matt, The miracle head will help a little, but could be a daily thing. Louis is correct, the carpet fibers are tired. The Kirby shampooer will also work as a carpet fluffer if you remove the shampoo tray. Both brushes fit that same head. Truthfully, if you have shampooed that carpet several times, you have taken much of the life out of the carpet. I am not a beleiver in shampooing carpets very often. If necessary once a year or very two years is a great plenty. Regular vacuuming should be all you need. If you clean carpets the dryer you can keep them the better. Just my opinion! Morgan |
