Thread Number: 32931
Vintage Filter Queen |
Post# 360258 , Reply# 2   10/3/2016 at 09:42 (2,753 days old) by dysonman1 (the county)   |   | |
That's a model LD31. They also made that same model in beige/tan. Since yours has the heat shield, the oldest it could be is 1979. Keep the cotton batting. The foam batting used today doesn't muffle the noise nearly as well. The batting was designed to also remove carbon brush dust from the exhaust, but the air flow is much greater out the bottom of the switch housing. That's normal. Your switch pedal's pad has been replaced, it should have been dark brown like the plastic bits of the machine.
Post# 360268 , Reply# 3   10/3/2016 at 11:36 (2,753 days old) by michvacguy (Michigan)   |   | |
Thanks everyone! Tom, where would the model and rating plate be hidden? As seen inside dome cap there is scare room, or was it very narrow on these models and fell off? |
Post# 360301 , Reply# 4   10/3/2016 at 16:39 (2,752 days old) by dysonman1 (the county)   |   | |
I don't know why yours is missing. It should be right under the cap. I have the same model, here's mine.
