Thread Number: 32795
Good and bad Electrolux Motors? |
Post# 359118 , Reply# 1   9/11/2016 at 08:53 (2,783 days old) by human (Pines of Carolina)   |   | |
Some more knowledgeable members can probably answer this with a greater level of specificity, but my understanding is that a relatively small number of 1401 (Super J) vacuums received defective motors when Electrolux had to quickly find an alternative supply of motors following a fire at their motor plant. When the bad motors began failing, Electrolux replaced them with good motors and put an extended warranty on the affected machines.
The ones that were repaired under warranty usually have a sticker on them stating the extended warranty. You can also identify those machines by their serial numbers but I don't remember exactly what to look for there. At this point in time, some 40 years after the fact, I would think it fairly unlikely to encounter a 1401 with a bad motor as they have probably either had the defective motors replaced or have been scrapped. In other words, if the thing is still running after all these years, it most likely has a good motor. |
Post# 359133 , Reply# 2   9/11/2016 at 16:29 (2,783 days old) by fantomfan57 (Central Texas)   |   | |
That makes perfect sense. Here are the shots of the 1521. The screen print label says Ultralux Classic, the Classic did not show up in the picture. It is, my favorite after my Lewyt. |
Post# 359343 , Reply# 5   9/15/2016 at 08:59 (2,779 days old) by kloveland (Tulsa)   |   | |
Where is the motor? The snap in connector connects to an identical female connector wire coming from the motor. I believe the other motor wire (there should be two wires coming from the motor) connects to the piggy back connector.
Did you label or draw a picture of the wires when you took the motor out? Once you have the motor in it should be more clear. I guess I'm unclear of what is going on here. Maybe I misread. |
Post# 359344 , Reply# 6   9/15/2016 at 09:14 (2,779 days old) by kloveland (Tulsa)   |   | |
Post# 359345 , Reply# 7   9/15/2016 at 09:21 (2,779 days old) by kirbyvertibles (Independence, KS)   |   | |
Post# 359359 , Reply# 10   9/15/2016 at 14:42 (2,779 days old) by blknblu (CT)   |   | |
don't give up on the Silverado. Post some pics of the what the vac looks like. We might be able to work something out. I have a running one with a rusty shell. |
Post# 359383 , Reply# 13   9/16/2016 at 06:59 (2,778 days old) by fantomfan57 (Central Texas)   |   | |
you mentioned working something out? What did you mean? |
Post# 359397 , Reply# 14   9/16/2016 at 11:09 (2,778 days old) by blknblu (CT)   |   | |
give me a shout.
Post# 359478 , Reply# 16   9/17/2016 at 14:45 (2,777 days old) by fantomfan57 (Central Texas)   |   | |
I mechanically restored the Silverado! Now for the cosmetic work and gathering of the attachments/wands/hose and PN. |
Post# 359489 , Reply# 17   9/17/2016 at 21:25 (2,776 days old) by Real1shep (Walla Walla, WA)   |   | |
Curious to see what it will pull in inches of water....do you have a gauge? If you've done the motor right, should pull over 70"....some will pull 80"
Kevin |
Post# 359528 , Reply# 18   9/19/2016 at 04:20 (2,775 days old) by fantomfan57 (Central Texas)   |   | |
I do not, but suction is excellent...sounds great too. |
Post# 359634 , Reply# 19   9/20/2016 at 11:41 (2,774 days old) by Real1shep (Walla Walla, WA)   |   | |
love to hear yet another one up and runnin'!
I recently bought a Super J with dismal suction, but very nice otherwise. I bought a rewound armature for it and am looking forward to a full restoration eventually.
Kevin |
Post# 359645 , Reply# 20   9/20/2016 at 14:22 (2,774 days old) by human (Pines of Carolina)   |   | |
Post# 361303 , Reply# 23   10/21/2016 at 20:04 (2,742 days old) by fantomfan57 (Central Texas)   |   | |
I has lasted all this time and I actually ran it last week, no problem. Having lasted this long it may be that this one was replaced. I would have to look at the motor itself, but I am not motivated to take it apart at this time. |
Post# 361377 , Reply# 24   10/22/2016 at 23:08 (2,741 days old) by Real1shep (Walla Walla, WA)   |   | |
it's hard to speculate after all this time, if a canister has the original or a replacement motor....unless there's a stick with the five yr warranty like on the Super J's. Kevin |
Post# 361920 , Reply# 26   11/3/2016 at 13:08 (2,730 days old) by Real1shep (Walla Walla, WA)   |   | |
Use of a hair dryer is an excellent tool, as they have to stretch a bit to snap in. Or a heart gun on its lowest setting. I found some nice bumpers on eBay for my Super J. The faded lettering I went over with the appropriate colored Sharpie...looks great/fresh.
Kevin |
Post# 361922 , Reply# 27   11/3/2016 at 13:43 (2,730 days old) by human (Pines of Carolina)   |   | |
Post# 361949 , Reply# 29   11/4/2016 at 03:03 (2,729 days old) by fantomfan57 (Central Texas)   |   | |
Good idea and info. I will have to check my vac's for the logo detail. |
Post# 361977 , Reply# 31   11/4/2016 at 14:05 (2,729 days old) by human (Pines of Carolina)   |   | |
The red borders on both of my 1205s are badly faded. Truth be told, I wasn't aware the red stripe was even there until I read about it on this forum and looked closely at the one I had at the time (and still have) and could see the faded remnants of red. When I got the second one this summer, I could see the red borders a little more clearly but they were still very faint.
Post# 361986 , Reply# 34   11/4/2016 at 15:45 (2,729 days old) by human (Pines of Carolina)   |   | |
Post# 361987 , Reply# 35   11/4/2016 at 16:00 (2,729 days old) by ronni (USA)   |   | |
Post# 361998 , Reply# 37   11/4/2016 at 21:02 (2,728 days old) by human (Pines of Carolina)   |   | |
