Thread Number: 32706
Electrolux Marque |
Post# 358366   8/29/2016 at 13:28 (2,767 days old) by bill57 (Cleveland, Ohio)   |   | |
How can I get to the on-off switches. |
Post# 358370 , Reply# 1   8/29/2016 at 14:40 (2,767 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 358393 , Reply# 2   8/29/2016 at 20:46 (2,767 days old) by bikerray (Middle Earth)   |   | |
The on off switch is mounted to the underside of the top cover. It is a slide switch. To get to the switch there should be a screw at the front of the cover and two screws under the blower cover. There may be one going through the handle as well, once you take these out the cover will come off and you will see the switch mounted to the underside of the cover.
Post# 358432 , Reply# 3   8/30/2016 at 14:46 (2,766 days old) by bill57 (Cleveland, Ohio)   |   | |
Thanks. Something is no longer making contact. I got it to go on a few times by pressing the on-switch repeatedly, but now the motor no longer goes on. |
Post# 358433 , Reply# 4   8/30/2016 at 14:58 (2,766 days old) by human (Pines of Carolina)   |   | |
Once you get in there, you should be able to use a multi-tester (a.k.a. a volt ohm meter) determine whether it's the actual switch that's the problem of whether there's something worn out on the cosmetic switch cap that you push on when you turn the machine on and off. It may be as simple a spritzing a little contact cleaner into the switch and working it back and forth a few times or it may require actually replacing it.
The link below shows a step-by-step procedure for disassembling a Diamond Jubilee machine. Maybe it'll be close enough to your Marquis to be at least somewhat useful. CLICK HERE TO GO TO human's LINK |
Post# 358586 , Reply# 5   9/2/2016 at 09:47 (2,763 days old) by kirbyvertibles (Independence, KS)   |   | |
Post# 358605 , Reply# 6   9/2/2016 at 14:49 (2,763 days old) by human (Pines of Carolina)   |   | |
