Thread Number: 32521
Vorwerk in US |
Post# 356913 , Reply# 1   7/31/2016 at 11:44 (2,824 days old) by myles_v (Fredericksburg, VA)   |   | |
Welcome to Vacuumland!
An American vacuum cleaner that can be as versatile as a Vorwerk (albeit heavier and more of a pain to use) would be the Kirby. They're good deep cleaners, are able to dry shampoo carpets, and they sell a variety of different tools and accessories. I'm aware of a couple people who use step-down transformers in order to use vintage Hoovers from Europe here in America, but I'm unsure of any specifics about it so I'm not of much help there! I'm attaching a photo of one of my Kirbys, a G6. I personally prefer the look of this model, the features of the G3-Ultimate G, Sentria, and Avalir lines have remained mostly the same. I have heard that the Avalir has an improved shampoo attachment, though. My second photo shows where the attachments connect to the cleaner at. Hopefully I've helped a bit! Good luck on your search for a solution :) Myles |
Post# 356917 , Reply# 2   7/31/2016 at 13:38 (2,824 days old) by eurekaprince (Montreal, Canada)   |   | |
I have used 220volt vacuums here in Canada with a step down converter with no problem. If you are living in a residential home or condominium flat that has a full-size laundry room, I think the washer/dryer machines run on 220volts. All you would have to do is pay an electrician to install a separate 220volt plug for you. You would need a very long 220volt European extension cord though to use your new Vorwerk 200 around the house.
Kirbys are very, very different in that they are far heavier than the Vorwerk. And not as modern in design and style...in my opinion. Maybe you could work with Vorwerk in Germany to bring back their vacs to North America? It would be great to have them in our vac shops alongside other German vacs like Miele and Sebo. |
Post# 356924 , Reply# 3   7/31/2016 at 15:33 (2,824 days old) by vacerator (Macomb Michigan)   |   | |
to install a 220 volt dedicated circuit than to step up from 120 to 220 volts via a transformer. I did that for my German Marklin trains, and they run better on 220 than 120. |
Post# 356961 , Reply# 5   8/1/2016 at 07:27 (2,824 days old) by vacerator (Macomb Michigan)   |   | |
There are punch outs on the sides and bottom of panels. A short section of conduit to another small box for the new circuit breaker can be added. Now if your exhisting house power is under 150 amps., it may be an issue. |
Post# 357015 , Reply# 6   8/2/2016 at 03:17 (2,823 days old) by tolivac (Greenville,NC)   |   | |
ALL of the slots in my panel are used-so it would have to be replaced to add another circuit-then that could lead to new service-200A instead of 150A-NOT worth it in my case.Don't know if the other homes on my circle have 200A. |
Post# 357020 , Reply# 7   8/2/2016 at 08:36 (2,822 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Hi Vorwerkfan - welcome!
I recently bought in a much longer cord for my Vorwerk from Germany and it has a 2 pin plug as standard. I had to buy an adaptor plug for usage in the UK. Im not too sure about voltage changes in the U.S though - if you can buy in a U.S cord with a U.S fitted plug, you can in theory use that cord on the Vorwerk vac you have; that's the beauty with Vorwerk as you know since the handle and cord are separate, replaceable items. |
Post# 357131 , Reply# 8   8/4/2016 at 08:06 (2,820 days old) by myvacsrock (USA)   |   | |
a Sebo Felix? That's about the closest thing we have here to a modern day Vorwerk. |
Post# 357143 , Reply# 9   8/4/2016 at 14:27 (2,820 days old) by panasonicvac (Northern Utah)   |   | |
Post# 357173 , Reply# 10   8/5/2016 at 05:57 (2,820 days old) by eurekaprince (Montreal, Canada)   |   | |
Unfortunately, none of the other German vacs (Sebo, Lindhaus, etc) come close to the unique design of the Vorwerk. Though I have no idea of the cleaning performance of the latest model and its various attachments, it is indeed an entire category of vacuum cleaner unto itself: from the dry cleaning powder option, to the window pane cleaning system, to the electrically powered Polsterboy upholstery tool, the Vorwerk offers really unique cleaning opportunities that no other vac of its size and weight and design offers. It would be great to see it return to the North American market as the polar opposite of the bagless vacs sold at big box stores here.
Post# 357176 , Reply# 11   8/5/2016 at 08:55 (2,819 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
There are some unique features that Vorwerk offer with their uprights in general but versus the SEBO Felix there are some similarities. Variable suction control, swivel neck, brush roll on/off (with previous Vorwerk PN heads such as the EB350 & EB351), the ability to lie flat to clean under low furniture, long manual cord on board, even changing over to hand held design where in the U.S you can buy a shoulder strap for a similar Vorwerk like shaped cleaning function. The dust bag capacities are also similarly low with 3 litres, 3.5 litres and then there's also SEBO's DuoP dry cleaning powder. Kobosan powder does seem to work; but I'm impatient sometimes and find rubbing some of the powder manually into the carpet by hand takes a stain out as opposed to trying to keep control of an upright that feels like a hover lawnmower.
What the Felix does offer is a trade off; a far heavier vacuum cleaner by its design, far more substantial build quality, slightly more motor noise, but still low energy rated, better value dust bags, hose on board with cleaning tools, manual height adjustment and simpler filtration. The Vorwerk VK200 is far more high end, not just judged by the price.
Currently in the UK you could buy yourself three or four SEBO Felix uprights for the price of one Vorwerk VK200 with its PN head. |
Post# 357213 , Reply# 12   8/6/2016 at 06:29 (2,819 days old) by myvacsrock (USA)   |   | |
If you read what I said, I do believe i said "about the closest thing" So I don't believe I'm wrong here. But hey, thanks for the insight. |
Post# 357216 , Reply# 13   8/6/2016 at 08:10 (2,818 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Well that wasn't a response to you I made, but to Eurekaprince who feels that no other brand including SEBO comes close.
Like some other brands, there's always several unique factors with every appliance and vacuums are no different. I'm not slating Vorwerk; I wouldn't have gone out and bought an older one for nothing and I love using my Vorwerk. As I said previously, at least Vorwerk have designed the optional floor heads with universality in mind; previous model owners can consider those upgraded floor heads for their existing Vorwerk. |
Post# 357439 , Reply# 15   8/10/2016 at 16:42 (2,814 days old) by bisonian (Where the buffalo roamed! (Ocala, FL))   |   | |
Eurekaprince, a minor correction. Lindhaus -- despite the name -- is actually Italian, not German. |
Post# 357448 , Reply# 16   8/10/2016 at 18:33 (2,814 days old) by eurekaprince (Montreal, Canada)   |   | |
Thank you for that correction, Rick. :-)
I always found it odd how so many brandnames don't match their country of origin! Rowenta sounds like it comes from Spain, not France. Miele sounds like it comes from France and not Germany. Lindhaus indeed sounds like it comes from Germany, not Italy. And there was/is a French company I think named Astor Martin (an Electrolux subsidiary) which sounded more like it came from the UK, not France. And then there is the confusion between Sebo and SEB/Tefal.... :-) |
Post# 357449 , Reply# 17   8/10/2016 at 18:39 (2,814 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 357451 , Reply# 18   8/10/2016 at 18:43 (2,814 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Post# 358025 , Reply# 19   8/21/2016 at 10:08 (2,803 days old) by myles_v (Fredericksburg, VA)   |   | |
I just saw your response to my reply, I just wanted to note that while I do own a cleaning business, I most definitely do not use Kirby vacuums in that business. Much too heavy to transport from house to house. I only offered that as a suggestion because they are very versatile, regardless of how complicated and heavy they are.
I wish you luck with getting a Vorwerk to work well here in the states! A step-down transformer should be a good solution for you :) |
