Thread Number: 32421
Kirby Classic III Fan - Ready for Change? |
Post# 356115   7/15/2016 at 23:48 (2,812 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Is it true that when rust develops around the fan shaft, as can be seen on my Classic III, would that be a sign that time is running out for this metal fan?
Thank you in advance with any solution you may have... ~Ben |
Post# 356124 , Reply# 1   7/16/2016 at 02:52 (2,812 days old) by tolivac (Greenville,NC)   |   | |
What condition are the trailing edges of the fan in-the parts covered by the fancase-any bent or nicked blades? |
Post# 356130 , Reply# 2   7/16/2016 at 04:19 (2,812 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 356138 , Reply# 3   7/16/2016 at 09:50 (2,812 days old) by dysonman1 (the county)   |   | |
It is NOT time to replace the fan, just because there's rust on the belt drive shaft. Look at the inside of steel wands for canisters, they rust from the humidity in the air. Seventy year old Kirbys with their original fans (plus rust on the belt drive shaft) are still being used to clean with today. The only real reason to replace the Kirby fan is for an unbalanced situation due to a broken blade.
