Hello everyone: just bought a GE AVT-810 canister vacuum, non running condition. When I opened her up, found a single pole switch with two screw terminals, both wires from plug disconnected from it and an orange and blue wire coming from the motor, also disconnected. Assuming this is the obvious problem, where do the wires go? I'm assuming one wire each from the plug to different terminals on the on/off switch and then the orange and blue wire also to one or the other terminal? Any help would be greatly appreciated...
-Thanks,
Clarence
Post# 355206 , Reply# 1   7/2/2016 at 19:43 (2,825 days old) by blknblu(CT)
