Thread Number: 32203
PN-4A powerhead circuit breaker |
Post# 354399 , Reply# 3   6/23/2016 at 12:17 (2,857 days old) by human (Pines of Carolina)   |   | |
I've replaced the hand grips on a couple of those hoses. It's pretty easy. You just need a Phillips screwdriver to take the screws out of the panel on the bottom of the grip and gently lift it away. Then the handle easily slides off the end of the hose. Put the new handle in place, snap on the bottom panel, replace the screws, and you're good to go in less than five minutes.
Hint: If you're replacing your damaged hand grip with a used one, install the best pieces of what you have. The last time I replaced a hose grip, the metal end was crushed just enough that it wouldn't connect to a wand or tool but the plastics were in good shape. The grip I put on to replace it had a cracked bottom panel and was missing its screws so I used the better bottom panel and screws from the one with the crushed end. The plastics are slightly different colors but it works just fine. |
