Thread Number: 32085
Hoover Windtunnel Self-Propelled. |
Post# 353429 , Reply# 1   6/7/2016 at 17:53 (2,878 days old) by Durango159 (State College, PA)   |   | |
In the upright position, the brush roll is supposed to be shut off on that. So that is good!!
How is your brush roll itself? You mentioned checking belts but I would take out the brush remove the end caps, clean and grease the bearings. Then check your on/off brush roll switch to ensure that is fully locking into either position and not hanging loose causing an issue when the resistance of the head hitting the carpet occurs. The springs really shouldn't wear out like that I wouldn't think. I'd be looking more in the area of all screws being tight, not stripping and that there are no cracks in the housing anywhere causing the tensioner to get loose. Tensioners can wear out, so check the tensioner arms, full mobility, etc. |
