Thread Number: 32024
Installing a Kirby aluminum fan DS 50 |
Post# 352799 , Reply# 1   5/26/2016 at 08:04 (2,890 days old) by bikerray (Middle Earth)   |   | |
You may be using a fan from a different model where the shaft from the fan isn't long enough to provide enough space between the bearing plate and the underside of the fan.
Also are you putting the bearing in the bearing plate? Which way is the step of the bearing facing? You might have the bearing in the plate backward. Next are the screws in the bearing plate scraping against the back of the fan? |
