Thread Number: 31914
Best practice for washing cloth bag? |
Post# 351859 , Reply# 1   5/9/2016 at 08:09 (2,906 days old) by HooverCelebrity (Germany)   |   | |
Hand washing in a mild detergent is completely fine. I've done the same with my PowerMax. Just let it hang to dry! |
Post# 351891 , Reply# 2   5/9/2016 at 13:54 (2,906 days old) by MarcSchroeder ()   |   | |
@HooverCelebrity, thanks for the tip! Follow up question, do you think it's okay to leave the bag topper/spring attached while doing this? |
Post# 351896 , Reply# 3   5/9/2016 at 15:59 (2,906 days old) by HooverCelebrity (Germany)   |   | |
You can probably leave it all attached, but I've always removed them. I like to leave 'no stone unturned' when servicing a machine. |
Post# 351904 , Reply# 4   5/9/2016 at 17:00 (2,906 days old) by pinkge (Indianapolis,Indiana)   |   | |
in luke warm water with Cheer color laundry soap.Rinse in cold water and hang it to dry.After it is dry spray with Magic Sizzing. It will give the bag a little body and will not restrict the air flow. Michael |
Post# 352070 , Reply# 5   5/12/2016 at 13:25 (2,903 days old) by floor-a-matic (somewhere)   |   | |
Vacuum the bag first before washing it; I use the Compact or Lux L with SideKick |
Post# 352092 , Reply# 6   5/12/2016 at 23:03 (2,903 days old) by MarcSchroeder ()   |   | |
Thank you both for the tips! Turns out the bag was incredibly dusty. Looks better now. |
Post# 352533 , Reply# 8   5/21/2016 at 00:47 (2,895 days old) by Durango159 (State College, PA)   |   | |
I've vacuumed bags before but usually with a dusting brush or bristled upholstery nozzle. I'd worry about a rotating brush being too aggressive on the material. Washing is the main thing! I've used Woolite or just a tad of Persil laundry soap. Hang/ lay flat dry. I remove springs on bags I wash or try not to get water in that area. I don't soak cloth bags long. It's more of a bobbing in the soapy solution and then out, so lettering doesn't fade and definitely no rust on the spring.
