Thread Number: 31635
Where can I find Vacuum adapter from Hoover to Electrolux ? |
Post# 349547   4/5/2016 at 04:07 (2,942 days old) by delaneymeegan (Mary Richards lived here)   |   | |
Post# 349558 , Reply# 1   4/5/2016 at 07:10 (2,942 days old) by blknblu (CT)   |   | |
yes, i have seen one. Aftermarket (perhaps Centec) |
Post# 349577 , Reply# 2   4/5/2016 at 11:57 (2,941 days old) by delaneymeegan (Mary Richards lived here)   |   | |
Post# 349690 , Reply# 3   4/6/2016 at 21:47 (2,940 days old) by Durango159 (State College, PA)   |   | |
While there are universal wands as posted above which will help in the right scenario go from a standard Hoover to more of a Eureka pig tail style with pin lock or or some central vacs with the pin lock, you do need to be careful.
Is your Electrolux a normal round metal wand with pin like projection?? Many Luxes have more or less an exclusive Electrolux/ Aerus wand setup with plastic to plastic that is their own unique system. Filter Queen is the same with everything from 2003 and newer having an exclusive tool lock system only to Filter Queen. Even most of the Eureka designed Electrolux units found at Lowe's Hardware and many other stores over the years have more of a square shaped wand to hose connection which is exclusive to them. Most Hoover power nozzle plugs over the years have either been a flat 2 prong or a T- shaped plug which may be a 2 or 3 prong wire. The flat 2 wire would fit older style Eureka non gas pump style hose grips like what would be found on their Rotomatic, Rally and Powerline power teams as examples. However the flat 2 prong Hoover plug would not fit Kenmore Hose handles, or many central hose handles properly. You could rewire the Hoover power nozzle too though with a wire to fit to fit your needs. Best of luck with your transformation. But do a lot of research and perhaps check with your local Central vacuum dealer/ or other vacuum stores and do trials on various machines to see what exact connection you need and what is available. There is this connector available for Hoovers which will allow a Hoover canister to utilize friction fit tools from say a Kenmore canister vacuum, but it will not allow a Hoover canister to run a PowerMate Jr. with out a pigtail wire. -- See Link below CLICK HERE TO GO TO Durango159's LINK |
Post# 349702 , Reply# 4   4/6/2016 at 22:52 (2,940 days old) by delaneymeegan (Mary Richards lived here)   |   | |
When they told me about the wand above, my first thoughts were 'how to keep it together since there is no button lock on the top Electrolux wand?'
I ordered a button release that will need to be slid into the end of the top Electrolux wand. HOPEFULLY it will work with the existing hole. If not, I will have to drill a hole. I'll know in a few days if it all works so easily .
As for terminology- I say traditional Electrolux wands, I refer to the wand sets that were used on Electrolux (and Kenmore, Eureka, and many others) before the advent of the plastic wands with built-in electric connections that started in the 90s sometime. My interested in Electrolux machines pretty much ends with the Ultralux Classic. I also am referring to traditional Hoover as the connection type shown on the picture above. Apparently, recently Hoover has retired that style (shoulder shrug). I don't know. I basically go to a current vacuum cleaner website and after a few minutes get bored and wonder where the Futura's and Spirits are. |
Post# 349828 , Reply# 5   4/9/2016 at 00:35 (2,938 days old) by Durango159 (State College, PA)   |   | |
I enjoy trying to help people solve an issue.
I am quite used to the Hoover raised button lock system where the hose end had a turning lock to secure it on the raised button. I grew up with and love that system. That system was used on every Hoover canister up until all of the bagless units came out and the Anniversary Windtunnel canister edition. Back in the 80's most uprights used this system too! Hoover Decade and Convertible attachments can be found with that style hose attachment lock. It worked well! Best of luck with getting your system configured. I'm sure I can speak for many when I say, be sure to post pictures! Would be great to see the new configuration! |
Post# 349849 , Reply# 6   4/9/2016 at 10:15 (2,937 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Delaneymeegan - First of all, let me apologize for not responding sooner. One of the parts websites I use as a reference was down for a few days as they were making changes to their website. Otherwise, I would have responded earlier.
"I ordered a button release that will need to be slid into the end of the top Electrolux wand. HOPEFULLY it will work with the existing hole." Ok. I understand what you are saying, but having a hard time picturing this. Part of the problem I could see with this setup is the sheath covering the upper wand might get in the way. Could we see a picture of this button release you ordered & how it works with the existing upper wand & sheath? There is another way to make this Hoover powerhead to Electrolux hose conversion work, & much simpler - go aftermarket. One wonderful aspect of this whole modern Made In China world we live in now is when companies start outsourcing to one manufacturer who makes vacuums for 10 different brands, you start to see parts & designs in common, particularly with aftermarket & central vac parts, & BOL & MOL vacuum designs. This makes customization & finding compatible parts that will work with our vacuums where the brand has discontinued parts availability much easier. If you look at the hose below, this is what I suggest you use. You will need to custom make your hose, since there is no aftermarket Electrolux metal canister hose available with this metal handle presently. I have attached a list of parts needed below to make the hose, as well as wands. This is probably going to be your simplest, & best, solution to what you want to do. Best part is, if you also order the metal Electrolux handle, you have a great spare hose to use with your Electrolux wand & powerhead if needed in the future. www.tiptoppartsusa.com/P-EL4802SA... www.tiptoppartsusa.com/P-FA3632/C... www.tiptoppartsusa.com/P-FA7018BK... www.tiptoppartsusa.com/P-FA4706/H... www.tiptoppartsusa.com/P-HV7015/S... You can use this Centec wand with cord management for Plastiflex hoses to hold your powerhead wire, & plug your pigtail cord directly into the cord without having to fiddle with the powerhead cord each time you want to use attachments or change wands, just leave the powerhead wire inside the plastic holder & unplug your pigtail wire & remove the metal handle. www.centralvacuumstores.com/centr... Here is the same wand on Tip Top Parts website they are selling under the Beam brand, yet for some reason when you click on the description they are showing it as 60 wands in 1 case. Unless you can find a vac shop that buys from Tip Top Parts or deals with Beam central vacuums & already has this wand in stock, better to get from the first website since you obviously don't want 60 wands :-) www.tiptoppartsusa.com/P-FA7032PE... And here is the Electrolux metal hose handle that you might want to also buy, just in case later on in the future you need to use the hose with your Electrolux wand & powerhead. www.tiptoppartsusa.com/P-EL7003/C... Best of luck setting up the Hoover powerhead to work with your Electrolux. Please post a picture of your whole setup when completed, if you don't mind. I have actually thought about this in the past, & I must say you have got me thinking again of doing this myself :-) Rob
Post# 349888 , Reply# 7   4/9/2016 at 16:48 (2,937 days old) by delaneymeegan (Mary Richards lived here)   |   | |
Thanks to CentralVacuumstores.com. I told them what I needed, and the operator knew right away some options.
Before I had a chance to even think about my final plans on how I would build my own, it arrived.
CLICK HERE TO GO TO delaneymeegan's LINK This post was last edited 04/09/2016 at 17:15 |
Post# 349890 , Reply# 8   4/9/2016 at 16:50 (2,937 days old) by delaneymeegan (Mary Richards lived here)   |   | |
This post was last edited 04/09/2016 at 17:07 |
Post# 349892 , Reply# 9   4/9/2016 at 16:58 (2,937 days old) by delaneymeegan (Mary Richards lived here)   |   | |
The plan is to mate to a spare typical traditional fit Electrolux UPPER wand (plastic band and release button).
However, a locking system is needed to keep them together, so the button device needs to go into the Electrolux wand HOPEFULLY the existing hole will line up with the hole in the new wand....
.... and it does.
Now, to use needlenose pliers to install the spring button. A screw driver helps to align.
Wheww. Exhausted. This was difficult.
And the final fit... is snug, which is what one would want. This post was last edited 04/09/2016 at 17:18 |
Post# 349896 , Reply# 10   4/9/2016 at 17:03 (2,937 days old) by delaneymeegan (Mary Richards lived here)   |   | |
Now to try it out.
My lovely Marquis is assisting me today.
An equally gracious Quadraflex has volunteered to demonstrate how well it functions when working together.
Post# 349897 , Reply# 11   4/9/2016 at 17:11 (2,937 days old) by delaneymeegan (Mary Richards lived here)   |   | |
Shhhh. Miss Quadraflex has whispered in my ear. She states that while she has no problem working with Mr. Marquis, she's a bit demure and finds this cord a bit uncouth. I have to agree.
I want to reinstall the upper Electrolux wand sheath and plug madam Quad into that. Will need an appropriate cord management device. Me thinks something velcro .? |
Post# 349928 , Reply# 12   4/10/2016 at 00:15 (2,937 days old) by Durango159 (State College, PA)   |   | |
That's a first that I've seen a setup like that!! Very cool that you made that work.
That's a neat system to have. That Quadraflex Powermatic nozzle was originally partnered with a gorgeous 2 speed Hoover Celebrity canister QS series. Do you still have that machine? I'd be interested in a photo of it. Your Quadraflex looks to be in gorgeous shape so I assume your suction unit would be too! Thanks!! |
Post# 350594 , Reply# 13   4/18/2016 at 14:51 (2,928 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 350611 , Reply# 14   4/18/2016 at 16:48 (2,928 days old) by delaneymeegan (Mary Richards lived here)   |   | |
Post# 350616 , Reply# 15   4/18/2016 at 17:38 (2,928 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 350636 , Reply# 16   4/18/2016 at 22:31 (2,928 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 350638 , Reply# 17   4/18/2016 at 22:48 (2,928 days old) by delaneymeegan (Mary Richards lived here)   |   | |
Post# 350674 , Reply# 18   4/19/2016 at 14:12 (2,927 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 352198 , Reply# 19   5/15/2016 at 17:00 (2,901 days old) by delaneymeegan (Mary Richards lived here)   |   | |
The upper wand sheath needed alteration, but the rest all fit together predictably.
This Silverado Special would work better with a light gray color Dimension 1000 Quadraflex.
Rob, Thank-you. This minty Quad came from an estate sale in the Southern Minneapolis area. It was paired with the canister and green hose, but no tools or tool holder. A woman from SanFrancisco bought those and the wands.
I have another mint Quad, a rust/beige Quad which I think was part of a lower end Dimension, a slate quad, and a Dimension 1000 dove Gray Quad all waiting to be cleaned and polished. I actually use these for daily vacuuming.
The convention sounds like a lot of fun. Where is it this year? ... and when? Time for a Vacation. CLICK HERE TO GO TO delaneymeegan's LINK |
