Thread Number: 31389
Electrolux XXX cloth bag upgrade |
Post# 347055   3/11/2016 at 11:30 (2,967 days old) by reo580 (Holland, Michigan)   |   | |
Hi.
This morning I was using my 1948 Electrolux XXX vacuum cleaner. My grandmother and my great grandmother bought it new together -they made every other payment and one week it was at my grandparent's house the other week it was at my great grandmother's house- they would shuffle it back and fourth on a weekly basis. But I digress, As I emptied it, I thought about the cloth bag and an idea hit me: what about using a replacement Lux 30/xxx bag as a pattern and making a new bag out of Micron Filtration Cloth- the kind used in industrial dust collectors. I wonder if anyone has tried this before? What are your thoughts on it? |
Post# 347059 , Reply# 1   3/11/2016 at 12:14 (2,967 days old) by vacerator (Macomb Michigan)   |   | |
I didn't know you could use a paper bag in it. I also have my grand mothers Z30. I never really use it, so I have not looked into it. |
Post# 347067 , Reply# 2   3/11/2016 at 12:59 (2,967 days old) by Vinvac (Dubuque IA)   |   | |
Post# 347076 , Reply# 3   3/11/2016 at 14:07 (2,967 days old) by kenkart ()   |   | |
To make a whole new bag out of newer and better material, and I think that is a fantastic idea, I don't see why it wouldn't work wonderfully. |
Post# 347082 , Reply# 4   3/11/2016 at 14:48 (2,967 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Hans, unfortunately it wouldn't work out well to replace the bag material with HEPA Cloth material. Problem with the HEPA Cloth bags is they are meant to be thrown out each time. If you have ever tried to empty the dirt from a HEPA Cloth bag thru the bag collar, you will find afterwards there is a layer of fine dust captured between the cloth layers. Assuming this is what Derek is referring to, the bag material would eventually become discolored & too dirty & would require washing, which you could only do so many times.
Derek, I think the best & simplest solution in your case, assuming you want better filtration, is to find a upright or canister HEPA Cloth bag of comparable length, & use it to make a bag liner for the cloth bag in your Electrolux. Simply insert the bag, wrap the bag around the metal bag collar, then put into the vacuum & put the bag cover on. You can either throw it out or empty it when the bag is full, & if you empty it, just throw it out when the bag is filthy & has been washed a couple of times & can't be used anymore. I would think a Hoover Type A HEPA Cloth bag would be the ideal length, & that bag can be bought easily in bulk online on Amazon. Rob |
Post# 347714 , Reply# 5   3/16/2016 at 08:18 (2,962 days old) by fantomfan57 (Central Texas)   |   | |
GREAT idea Bob! |
Post# 347720 , Reply# 7   3/16/2016 at 08:56 (2,962 days old) by reo580 (Holland, Michigan)   |   | |
Those are some pretty good ideas.
I'm thinking of upgrading the entire cloth filtration - eliminating the need for paper liners. I was thinking of the cloth dust collection bags used on Wood Shop dust collectors. The replacement Lux 30 dust bags have nice, new rubber gaskets and new metal rings, but the ones I have seen in person look like they have bed sheet grade muslin for the bag material. I have been thinking of using one of them as a pattern and using the dust collector bag (after cutting, trimming and resewing it to fit) on the replacement lux 30 bag ring. I can see a spring project forming.... I attached a link below CLICK HERE TO GO TO reo580's LINK |
Post# 347752 , Reply# 8   3/16/2016 at 15:45 (2,962 days old) by fantomfan57 (Central Texas)   |   | |
Let us know about your progress (pictures) and good luck with your project. |
Post# 375729 , Reply# 9   7/23/2017 at 11:39 (2,468 days old) by rainbowjoel (Dexter NM)   |   | |
I want do mine too! anyone made one yet? |
