Thread Number: 31314
Need help, hoover futura motor problems |
Post# 346409   3/5/2016 at 17:17 (2,967 days old) by icee (Indiana)   |   | |
So, I pulled the cover off the "powermatic", taking a look inside to finally find out what's making the horrible screeching noise. Turns out it's the motor. Took the belt off and spun the motor by and and it squeaks/squeals something fierce. It's a model s3557, 10.3 amp. Finding a motor or a nee "powermatic" head has been a major pain, can anyone help me locate one?
Post# 346416 , Reply# 1   3/5/2016 at 18:14 (2,967 days old) by blknblu (CT)   |   | |
For the power nozzle? Try part number 43177062, I see one on ebay - it looks like a discontinued part Looks like it takes a "rubber band" belt, no grooves, just flat
Post# 347002 , Reply# 2   3/10/2016 at 18:17 (2,962 days old) by Durango159 (State College, PA)   |   | |
Sounds like a bad bearing in the power nozzle. Those power nozzle motors are very simple to disassemble and clean. I have never serviced the sealed bearing on one though. Luckily those motors are fairly easy to get a hold of. They can be costly though.
As ridiculous as this sounds, you may even find an entire power nozzle cheaper than the motor itself on eBay!! From there you can switch your top hood or switch the motor or just use the freshly purchased power nozzle as is. It may even be an upgrade to yours with a headlight and dual row brush roll!! The motor for your machine has a triangular formation screw connection to the base. Any motor from any PowerMax, Futura or Windtunnel---original generation style, power nozzle will work. Also Turbo Power 5000, 6000, 7000, 7500, Encore Supreme, any of those power nozzle motors will work. Depending on the one you get, you could convert any T shaped 3 prong wire to a standard 2 prong wired for the power nozzle! The only reason for the 3 pin system was for the headlight to run on a separate terminal that would stay running while a brush roll on/off switch cut off power to the other 2 terminals which powered the motor. As you can from the inside of my Windtunnel power nozzle below, it is the same motor design as what would be in your Futura! What would not fit in your nozzle would be a motor for a Quadraflex PowerMatic or Celebrity Powermatic!! Nor a motor from current market compact style Hoover power nozzles.
Post# 347041 , Reply# 3   3/11/2016 at 09:42 (2,961 days old) by 3rdGenVacGuy (Columbus, Ohio )   |   | |
I still have two in stock. They originally sold for $60. I would sell one to you for $30 shipped. I have a Paypal account. The Paypal account is not my email listed under my user name for this forum, but you could contact me from there. |
Post# 348511 , Reply# 4   3/24/2016 at 23:18 (2,948 days old) by icee (Indiana)   |   | |
Post# 348592 , Reply# 5   3/26/2016 at 02:14 (2,947 days old) by Durango159 (State College, PA)   |   | |
There are resources here. Let us know how we can help!
The price that 3rdGenVacGuy is offering is extremely cheap actually. On eBay the Futura/ PowerMax style motors are usually in the $85 range or more! It is not a universal fit motor for that power nozzle due to the triangle formation that it has to screw into for the housing! |
