Thread Number: 31279
Kirby Model 510 |
Post# 345985 , Reply# 1   3/1/2016 at 21:08 (2,949 days old) by KirbyCollector (Columbus Ohio USA)   |   | |
Well, you can it just depends on which kind of metal fan your using. The 515 style ten blade fans are the only kind of ten blade fan that can fit on a 510.
Replacing the beatleings is easy, after you remove the fan you unscrew four screws and pull the round plate off and you can remove the armature and do whatever you need to do |
