Thread Number: 3124
Kirby G4 Transmission question |
Post# 34642   3/13/2008 at 16:29 (5,859 days old) by thunderhexed (Edmond, OK)   |   | |
On my G4, when I am pushing the cleaner with the tech-drive in neutral, and the power off, I hear a noise coming from the transmission area, like gears are turning.. is this normal? Sometimes it does it and sometimes it doesn't..usually whenever I turn to go around a corner is when it starts the noise. Any ideas?
Post# 34647 , Reply# 1   3/13/2008 at 17:31 (5,859 days old) by vintagehoover ()   |   | |
It seemed to work fine, though...I've sold it now, so I'm not too worried! |
Post# 34650 , Reply# 2   3/13/2008 at 17:47 (5,859 days old) by kirbymodel2c (Nottingham, England)   |   | |
Hi. No its not normal. The gear/lever the flicks it in to drive is not coming out fully so it catches the gears in side when its suppose to be out of gear, The tech-drive just needs cleaning out and a bit of lube put on it so it can slip all the way out again. That's normally the most common problem. Hope you get it sorted. jb |
Post# 34697 , Reply# 3   3/14/2008 at 08:27 (5,858 days old) by louvac (A)   |   | |
What James is referring to is a small "finger-like" lever that wears and needs to be replaced. This usually takes care of the problem. |
